Injector scaling smaller than actual size
Old Jul 22, 2013, 11:53 AM
Turbobudz's Avatar
Well gurus.
Ok heres my question, my injector scaling of my jdm Evo 7 is 450cc. Why would this be when standard injectors are 560cc?
Is there a reason why someone would do this? My IDC is hitting 120% at 220 load...
Please shed some light. Been trying to search what is happening but didn't know exactly what to look for. Haven't hooked it to my WB yet.
Thanks
Old Jul 22, 2013, 12:44 PM
Raptord's Avatar
All injectors are scaled ~15% lower than their rated flowrate (for pump gas at least), this is normal.
Old Jul 22, 2013, 12:51 PM
meckert's Avatar
Also you scale the injector for the fueling needs of the car-- you could run 2000's and scale at 750.
Old Jul 22, 2013, 01:05 PM
Turbobudz's Avatar
Thanks for the quick reply lads. And what about my IDC %?? Anything to worry about?
Old Jul 22, 2013, 01:20 PM
Raptord's Avatar
The car would probably run rich despite the fuel trims maxing out trying to reach stoich with that big of a gap between rated flow and scaling
Old Jul 22, 2013, 02:00 PM
meckert's Avatar
Sure, more for the sake of making a point aside from being correct. As you know many folks buy larger injectors that they scale to meet demands today with the intention of running say e85 later and the need to rescale for that purpose without having to buy new injectors..
Old Jul 22, 2013, 11:22 PM
Turbobudz's Avatar
Thanks very much.. All much clearer now
Old Jul 23, 2013, 01:01 PM
todd6027's Avatar
Where in Ireland are ya ???
Old Jul 26, 2013, 10:17 AM
Turbobudz's Avatar
Kilkenny
Old Jul 26, 2013, 01:54 PM
todd6027's Avatar
Originally Posted by Turbobudz
Kilkenny
Im next door , down in wexford
Old Jul 26, 2013, 10:30 PM
Turbobudz's Avatar
ha ha thats handy to know if i get stuck with anything Im in New Ross alot of the time. I must call down to you someday
Old Jul 27, 2013, 10:10 AM
todd6027's Avatar
Do m8 , do you know john in new ross had a white 5 , now has a black 4wd evocolt ???
Old Jul 28, 2013, 06:15 AM
Terror Rising's Avatar
Your high IDC% means you're requiring more fuel than your injectors can deliver. 120% of your scaled 450cc is 540cc which is super close to your 560cc max rating. I'd dial that boost down a bit, connect the WB02, and address your fuel issues real quickly.
Old Jul 30, 2013, 05:36 AM
Turbobudz's Avatar
@Todd ya i know of him and seen the colt around. Very quick little thing . I bought the alloys off his E5.
Old Jul 30, 2013, 05:39 AM
Turbobudz's Avatar
I cant cause the actuator is uprated. Came with the 9 turbo. Bigger injectors be the next step after i check AFRs? Ill try log by the weekend because of work commitments.
Quick Reply: Injector scaling smaller than actual size
