Should I switch maps when moving to a 10.5 housing
Hey All,
I hope this isn't a stupid question. I have a basically stock 03 running the Tephra V7 version of 94170015. My small 9.8 housing was leaking out of the flapper pretty badly. I got a 10.5 housing to replace it. Is it enough of a chance that I need to possibly run the 05 maps? I haven't done any real tuning, yet, just scaled and smoothed out the map. I won't be getting a wideband for another month or so.
Thanks,
Brady
Thanks,
Brady
1. YOU SHOULD NOT BE TUNING WITHOUT WIDEBAND and if you do leave it on the rich side....thats like walking into a dark room blind folded
2. No you dont need to change the maps just because you changed the hotside. Im assuming since your turbo will spool a little later it will hit different load points on your map. you will have to retune the timing/fuel/ (ve if u have SD)
I'm not tuning... I just smoothed out some of the giant jumps in the timing map a little. I haven't touched the fuel map other than to scale it to the same as the timing. I don't plan on tuning until I have a wideband. Just got my Omni and was able to confirm that I wasn't getting full boost until after 4k. No reason to tune if the car isn't running right in the first place.
aggieEVO
20
Aug 21, 2013 11:02 AM
