help me,TephraMod V7 in my 88840017
Old Sep 11, 2013, 07:19 PM
kubaolong's Avatar
hi guys
sorry ,My English is not good
I have a question
my car: 2006 edm
mod: 88580714 TephraMod V7
18884001X - You can use 88580714 with no problems. Just ensure you copy your immobiliser AND 0xFFA bits (yes 0xFFA) otherwise the immobiliser wont work ) --ok
2Copy entire XML package to your ECUFlash XML def. directory for the EVO. Overwrite any files if needed. Edit ROM as needed copying over your Fuel/Timing/Immob/InjectorSize/BoostSettings/etc...) --ok
3:FAA bit.10 disabled ("weird unknown" timing pull at cruise)
FAA bit.09 disabled (cat-warmup ignition retard)
FBA bit.00 disabled (lean spool)
FCA bit.09 disabled (EGR Test)
--ok
Everything is good, but Launch Maps can't work why
Old Sep 12, 2013, 09:15 AM
211Ratsbud's Avatar
Does your car have two clutch switches?
Old Sep 12, 2013, 07:23 PM
kubaolong's Avatar
thank you so much,and I have solved this problem
tephra
Jun 23, 2022 09:46 PM
nuk1ear
Nov 27, 2016 05:13 PM
tephra
Aug 19, 2016 10:07 AM
Appauldd
Sep 21, 2015 08:39 AM
kassir
Nov 5, 2011 01:16 AM
Quick Reply: help me,TephraMod V7 in my 88840017
