knock sensitivity settings
OEM? Check the base tephra map for original settings. For most of us with built noisy motors you shouldn't have to add more than 20% to the multipliers. Some people ignore everything under 100 load as well but personally I do not think that is the best idea. You really need to know if it is actually knocking or if you have other driveline noise for the "correct setting".
Is it knocking? What are you running for boost? Is it pulling timing? AFR? I would go with OEM settings with your mods. If it's knocking I would look at your AFR, boost and timing.
here are current settings...
knock sensitivity load threshold
500 1000 1500 2000 2500 3000 3500 4000 4500 5000
159.375 159.375 159.375 159.375 130 139.375 139.375 139.375 139.375 139.375
noise adder
1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 70007500
15 15 15 16 17 22 22 22 22 22 22 22 22 22
noise adder triple gain
1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500
7 7 7 7 9 9 9 10 12 18 18 18 18 18
noise adder single gain
2 2 2 2 3 3 3 3 4 6 6 6 6 6
sorry for the mess, not sure how i can upload screen shots.
can someone help me out on this? do these look right or should something be changed.
thanks
noise adder
thanks
These are the stock settings. If a tune is not getting anywhere due to knock I'll have the customer verify phantom knock with a det can or stethoscope (depending) and adjust for a noisy motor if needed.
If you're on the stock block I'd highly suggest leaving it at stock settings and listen to your motor. Call me or pm me if you have any concerns. I'll try to watch this thread if you have any other questions.
thanks
thanks
Really only need to change the dip where it goes 19-19-18-19-20
YaroRS
23
Jan 28, 2010 05:38 AM
