Tuning Evo789 ACD
#167
Hi Dave, I found the error causing my ECUFlash crashing.
401404 XML, line 198. Scaling name is incorrect. Change name="SteeringAngle_ACD" to "SteeringAngle".
Cheers.
Cheers.
#169
Actually mate, looking further... "SteeringAngle_ACD" is still used in the AYC Rear Diff Proportioning Map. So, "SteeringAngle" will need to be added to the scalings or the scaling ref for the AYC Rear Diff Proportioning Map needs to be changed to "SteeringAngle". Is funny this never caused a crash though. :S
I looked at my version too, and it's one version after the one you use. Will be going back.
#170
Now that Matt Manke at ACD tuning.com appears to have disappeared from the ACD tuning world, is there any one in the USA that is on his level in tuning the 8-9 ACD ECU for street , track or off road use?
Looking for a tuner to do a auto x map and track map given my mods and driving style. Have Spare ACD ECU ready to go.
#172
I have been wanting to tune some ACD maps for others for a while. I have always needed testers but people I have talked to didn't seem interested. I Have been doing it for 3 years on my car with great results. I have only flashed my evo 9 with the stock rear diff and now a upgraded rear diff. I have 2 way coilovers, big rear sway bar, and stock power. The car can swing around easy. Right now I am testing the new 2D maps merline has found. I have been touching up the scaling but still uncertain how accurate my scaling is. The new 2D maps have showed me some new ideas to implement.
I am on stock power so someone with additional power will need delicate touch ups on the ACD tune. This is a reason why I haven't really shared any maps. As much as would like to I am still testing things out. Which is hard to release a finished map that I can trust people with. PM if anyone is interested. I am in SoCal. I'll be happy to help personally and maybe, hopefully put some maps that people can try
#173
Nice work in this thread. Very very promising. I actually have an ACD tuned by Matt as well as my stock ACD ECU, both the same versions. My car is up on jackstands right now while I fix some body panel. If I find time, I'm going to pull the ROM from each and see if I can do some comparisons to the changes.
If get to it before someone else does, I'll let you know what I find.
#174
#175
#178
#179
Question to All...
Has any newbe been able to Read their ACD ECU?
.....If you can Read it, then i am sure you can write
So my main question is: Has anyone been able to flash the K1 K2 and C1/T1 roms lately?
If you have what are your experiences?
What is your set up?
Has it been good or bad for your set up?
Do you have an untouched REAR LSD or upgraded REAR LSD? (this Part is really important to how the ACD Feels)
thanks for any input
