p0107 code with omni 4 bar
installed a omni 4 bar now im getting a p0107 code (Manifold Absolute Pressure ircuit Low Input) with it.
I use the this thread for the scaling values
https://www.evolutionm.net/forums/ec...evo-8-9-a.html
im using 88590015 map
Scaling values
0.51 25
0.90 49
1.29 70
1.68 96
2.08 120
2.45 144
2.85 170
3.24 195
3.63 255
"MAP Fault Trig: Mid VE Max #1" value 4.90.
"MAP Fault Trig: Mid VE Min #1" value 0.10.
"MAP Fault Trig High VE #1" value 0.51.
"MAP vs Baro" parameter 77.
"MAP Comparison" value 1.23.
"Periphery4 (FEA) Bits" table 0.
"Periphery2 (FCA) Bits" table. 0.
Scaling values
0.51 25
0.90 49
1.29 70
1.68 96
2.08 120
2.45 144
2.85 170
3.24 195
3.63 255
Defective omni map sensor. I did this exact thing and have had zero issues since doing so over a year ago. Or check to make sure that you didn't mess up the harness or wires leading to the harness while installing. No other reason you should be getting P0107 other then a defective unit. Good luck. :]
I had the same issue , what I did was disconnect and re-connect the map sensor connector and the CEL went away... again that's what worked for me.
You could really have a faulty sensor
mrfred
Feb 26, 2022 06:16 PM
