Map tracer tutorial?
When the log loads, there is a gray space with load and rpm axis. Right click in that space, choose load rom from file, at that point you will be able to see your logged info as well as your fuel or timing map. To change between the various maps in your rom you right click on the map and make your choice.
On the top, where the log info displays, you can move your cursor over the data points and it will display the info logged within that point.
I can make a more detailed how-to when I have time.
I hope this helps.
I hope this helps.
Profoxcg
Jan 20, 2008 09:51 PM
