Trying to figure out what "Load" item to log in EvoScan to use in ECUFlash.
After doing some logging and trying to tune on ECUFlash, I'm not sure which "Load" item to go off of (Load Calculated, Load11Bit4, ECULoad, Load 1Byte, etc). I'm using EvoScan 2.8 and Tephra V7, Load Calculated is the only one that looks to match but I'm not sure. Need somewhere to start if someone can point me in the right direction.
You should do a search for 2 byte logging of load and rpm and airflow. It's the best imo unless you're running a tephra mod then you would use 1 byte. You can swap to 2 byte logging pretty easily with some mods to the mut table, its dependant on what Rom you are using though in regards to which mut addresses to change.
06Black
Jul 6, 2016 12:43 PM
evo4mad
Oct 12, 2006 11:30 PM
