96530006 upgrade questions for Evo8 EUDM 2005
Hello, guys. I am a noob with Mitsubishi and trying to understand all reading threads, but still have some questions...
I have bought Evo8 2005 EUDM 2 weeks ago, it has light tune: some 272 cams(don't know which ones), full 3.0' exhaust, K&N intake, turbo from Evo 9, gearbox 6-speed from Evo 9 MR(or Evo 8 MR?). Today I've read my firmware with OpenPort 1.3 and EvoScan 2.9 and saw that it is 96530006. I want to upgrade firmware to 96530706, but a bit confused... I've found 2 .bin files(as seen in hex editor with slight difference in 3-4 lines) and 2 .xml files 77kb and 94kb(so I think it has big difference like Thermo Fan map and etc.) first bin and smaller xml was found in Tephra thread, dated 2010 year, second bin and bigger xml - 2011 year.(https://code.google.com/p/ecurom/sou...06-v7.xml?r=55)
So my confusion is which one set to take?? As I understand bigger xml has more patches/maps/settings and etc. What about bin files?
And 96530006 means Tephra Mod V5.10 ? (I see Tephra Mod options in EcuFlash).
Thanks in advance for help and sorry for my english I am from Ukraine.
My ROM included
My ROM included
Have found differences between two 96530706 ROM's:
[22:21:47.250] --- ROM comparison ---
[22:21:47.250] (ROM 1) | (ROM 2)
[22:21:47.250] filename: 96530706-TephraMod-phenem_2.bin | 96530706-TephraMod-phenem.bin
[22:21:47.250] size: 262144 | 262144
[22:21:47.250] empty: 13% | 13%
[22:21:47.250] memory model: SH7052 | SH7052
[22:21:47.250] metadata model: 96530706 | 96530706
[22:21:47.250] comparing maps...
[22:21:47.250] table ISCV Demand RPM Adder* (sub_1EFC0) has differences
[22:21:47.250] table ISCV Demand RPM Adder [rpm > 4500, load > 170, speed > 12 mph] (sub_1EFC0) has differences
[22:21:47.250] table ISCV Demand RPM Adder (Moderated by Baro, IATS) (FFFF6EA8) (sub_204B6) [sub_1EFC0] has differences
[22:21:47.250] table EGR System Enable/Disable has differences
[22:21:47.250] table ECU Periphery2 Hex has differences
[22:21:47.250] table ECU Periphery2 (FCA) Bits has differences
Maybe can someone explain? )
96530706-TephraMod-phenem.bin - original found in Tephra thread
96530706-TephraMod-phenem_2.bin - found at https://code.google.com/p/ecurom/
which one to use?... Thanks!!
About which XML to use - understood. What about ICSV values? Somebody has an idea? Thought that it is for MAP compensation, but this is MAF firmware. Maybe for big camshafts ?
