2011+ Brake Boost - Solved
Old Apr 24, 2014, 07:55 AM
mclaren's Avatar
Wait, So changing the value of 010A to 0400 Enables this Brake Boost Patch?
Old Apr 24, 2014, 08:28 AM
itzwolf's Avatar
Correct, it's simply increasing the "trigger" value higher than a value you can hit preventing the TPS closing code from engaging.
Old Aug 14, 2014, 08:32 PM
butters149's Avatar
how should I brake boost on an MR? how do I know if im doing it correctly or if its working?
Old Oct 1, 2014, 09:09 AM
tRUffleSHuffLE6's Avatar
So how does this work with an accessport?
Old Oct 1, 2014, 02:53 PM
tweak1509's Avatar
Im also looking for a way to do this with the accessport, any help would be great
Old Oct 2, 2014, 09:07 PM
franzcars's Avatar
I do not believe you can do this with the AP because you can not edit the map definitions and would have to wait to see if cobb adds it
Old Jan 15, 2015, 03:15 PM
ChrisWantsBoost's Avatar
I'm running a 2011 Evo with a 2010 rom via TephraV1. What map should I be using, and where should I place it?
Old Apr 10, 2015, 11:55 AM
EvoXEmma's Avatar
Lightbulb
Same address for 56920008? Does this work for SST as well?
Thanks for your help!
Old Sep 6, 2016, 01:59 PM
Lutekevo's Avatar
Good job..!
But can you show us how to make it works??
I mean where and how i have to make changes to disable it step by step?
I ve got my map on ecuflash and now what should i do.
I really apreciate any support
Old Dec 25, 2016, 02:12 AM
IGX
IGX's Avatar
Will this work on a 2009?
Old Apr 19, 2017, 02:19 AM
Evo9_Dubai's Avatar
Hi Guys, anyone has it for 56910309 ?
Thanks most appreciated.
Old Apr 20, 2017, 05:33 AM
RS200Z's Avatar
Here you go.
Code:
<table name="Brake Boost Minimum App (0x010A -> 0x0400)" category="Misc" address="54C3C" type="1D" scaling="Hex16"/>
Old Jun 6, 2017, 06:48 AM
sleandro's Avatar
Help to find...
Originally Posted by RS200Z
Here you go.
Code:
Hello! Would you please help me to find the correct address to my ROM? It's 58640002 from a 2011 Lancer Ralliart.
Thank you very much!
Leandro
Old Aug 2, 2017, 05:13 AM
richardjh's Avatar
Here are a couple more...
58640002
Code:
59570004
Code:
<table name="Brake Boost Minimum App (0x010A -> 0x0400)" category="Misc" address="54C4C" type="1D" scaling="Hex16"/>
Rich
Old May 22, 2018, 07:43 AM
tuning g's Avatar
Hi,
I Flashed a 59580004 rom into a 2015(59580006) evo and now i am having an issues with Brake Boosting I am not finding the Brake Boost dissable option which was present in the original read (2015) ant suggestions would be greatly appreciated
Regards Greg
richardjh
Sep 17, 2023 01:02 AM
tephra
Sep 13, 2021 01:07 AM
EvoXEmma
Dec 27, 2020 01:18 PM
tephra
Jul 25, 2016 02:21 PM
SharkyPR
Feb 21, 2016 10:49 AM
Quick Reply: 2011+ Brake Boost - Solved
