New Rom 56890014
New Rom 56890014
I was running rom 56890010 with mode 23 turned on. Recently, I had the dealership reflash the ECU for recall C1311W. Now when I pulled the ROM using Ecuflash, the ROM ID is 56890014 (attached). Of course, Ecuflash doesn't recognize this ROM and it's not in Golden's database.
Can someone upload the 56890010 or 56890013 hex to flash my ecu back to something defined in Golden's database? Or does anyone know a workaround for this?
56890014 is based off the 56890013 ROM. I just checked and did a compare, all tables matched.
new to this
I drive a 2008 Evo X what roms should I use?
Is the XML file for all evo X's? I'm going to paste it to my rommetadata folder what should I call it? "56290014 USA Evo X" or "56290014 USA 2008 Evo X"? I hope you see what I'm getting at?
Tonyjh91
im having the same issue can’t enable mode 23 on my 2011 Evo X gsr 56890014 inherits 56890009 i may have added one to many zeros any help greatly appreciated can I just use the 56890013 that’s already out ?
You should inherit 56890013.xml. It is easy to copy itzwolf's xml file to your metadata directory.
Then, change the values of these three tables : 'Mode 23 - IFMode 0x05 -> 0x23 #1', 'Mode 23 - IFMode 0x05 -> 0x23 #2', 'Mode 23 - IFMode 0x4D -> 0x5D #3'.
