Injector flow rate linearization table
Old Feb 19, 2017, 08:10 AM
  #76
ace33joe's Avatar
Thanks, Dave!
I was looking for something that can lower the AFR swing at idle with my FIC 1050SP, I am still struggling with cold idle / rpm fluctuation, but I think this helps too.
I think most cold idle / rpm fluctuation problem is related to the linearization table, so I will try Mychailo's FIC1100 setting along with his latency value which was a bit larger than mine, hope this fixes lean AFR stumble near 2.0ms fuel pulse logged (I have to also try the 2 byte sync FPW logging item to be exact as I suspect my 2 byte IPW includes latency vs. voltage value)
Not sure if I understood the items correctly, but the first two items affect fuel resume after fuel cut?
I think next two idle items affects fuel swing at idle.
Seems like stock value for 9417 is:
0.122%
0.122%
0.040 %
0.052 %
so I guess I should try about half the value since injector scale is 1008 cc/min vs 513 cc/min (stock)?
Thanks again!
Originally Posted by merlin.oz
Jeff, add this to you definition and then try lowering the Closed loop Idle Integral Gain value to help reduce the random swing.
for 9653:
<scaling name="I-Gain" units="%" toexpr="x/327.73" frexpr="x*327.73" format="%.3f" min="0" max="0.78" inc="0.00305" storagetype="uint8" endian="big"/>
<table name="Closed-Loop Integral Gain Settings" address="36B8" category="Closed-Loop Control" type="2D" scaling="I-Gain">
<table name="Conditions" type="Static Y Axis" elements="4">
<data>Closed-Loop I-Gain After Fuel-Cut, Decrease Fuel IPW (Lean)</data>
<data>Closed-Loop I-Gain After Fuel-Cut, Increase Fuel IPW (Rich)</data>
<data>Closed-Loop I-Gain Idle, Decrease Fuel IPW (Lean)</data>
<data>Closed-Loop I-Gain Idle, Increase Fuel IPW (Rich)</data>
</table>
</table>
Edit:
9653 has quite high stock gain values here:
0.051 to lean the mix
0.066 to enrich the mix
try something like:
0.021 to go lean
and
0.055 to go rich. Maybe a little lower.
Old Feb 20, 2017, 05:11 PM
  #77
ace33joe's Avatar
Quick update:
Lowering idle integral gain does help lowering the AFR swing at idle.
Cold idle rpm / AFR up and down is still there, but milder.
Will adjust ISCV vs. coolant table a bit more and hope I can narrow down the problem to FPW (linearization table).
Old Feb 21, 2017, 06:30 PM
  #78
merlin.oz's Avatar
Chriss, add these to your xml.
The first item is an updated version of what you already have.
The second item sets the gain under cruise and light throttle conditions.
<table name="Closed-Loop Integral Gain Settings" address="36B8" category="CLOSED-LOOP CONTROL" type="2D" scaling="I-Gain">
<table name="Conditions" type="Static Y Axis" elements="6">
<data>Closed-Loop Feedback Integral LEAN Gain - AFTER FUEL-CUT .</data>
<data>Closed-Loop Feedback Integral RICH Gain - AFTER FUEL-CUT .</data>
<data>Closed-Loop Feedback Integral LEAN Gain - HOT IDLE .</data>
<data>Closed-Loop Feedback Integral RICH Gain - HOT IDLE .</data>
<data>Closed-Loop Feedback Integral LEAN Gain - COLD IDLE .</data>
<data>Closed-Loop Feedback Integral RICH Gain - COLD IDLE .</data>
</table>
</table>
No I dont know where the HOT IDLE/COLD IDLE switch temp setting is hiding.
<table name="Closed-Loop Learning Gain Federal Spec per Zone" address="36BE" category="CLOSED-LOOP CONTROL" type="3D" scaling="I-Gain">
<table name="ZONE" type="Static X Axis" elements="6">
<data>Zone 0</data>
<data>Zone 3</data>
<data>Zone 1</data>
<data>Zone 4</data>
<data>Zone 2</data>
<data>Zone 5</data>
</table>
<table name="Condition" type="Static Y Axis" elements="4">
<data>Integral Enleanment Gain O2 FB, M/T TFILGN_F</data>
<data>Integral Enleanment Gain O2 FB, A/T TFILGD_F</data>
<data>Integral Enrichment Gain O2 FB, M/T TFIRGN_F</data>
<data>Integral Enrichment Gain O2 FB, A/T TFIRGD_F</data>
</table>
</table>
Buried in this table are the load and rpm set points for "Closed-Loop Learning Gain Federal Spec per Zone" integral gain settings.
Specifically, the last three entries, one Load (35%) and two rpm points (1312 and 2250).
Draw up a matrix and try and figure out which zone gets applied into the matrix.
My limited testing here has shown some pretty funky results on my nine.
<table name="Closed-Loop o2 Sensor Control Parameters (1.4)" address="159E" category="CLOSED-LOOP CONTROL" type="2D" scaling="Hex16">
<table name="FUNCTION" type="Static Y Axis" elements="18">
<data>159E CLOSED-LOOP Front O2 Sensor non-active judgement voltage XO2CHL 001F = 0.605 Volts V*5/256 .</data>
<data>15A0 CLOSED-LOOP Front O2 Sensor RICH/LEAN judgement voltage XO2RLL 001A = 0.508 Volts V*5/256 .</data>
<data>15A2 CLOSED-LOOP Front O2 Sensor non-active Baro Limit XBPO2LVL 00B7 = 679 mmHg Bp*760/204.8 .</data>
<data>15A4 CLOSED-LOOP Front O2 Sensor non-active judgement volt XO2RLOFST 0000 = 0.000 Volts V*5/256 .</data>
<data>15A6 CLOSED-LOOP Front O2 Sensor non-active judgement time X02TST 00FF = 127.5 Sec T/2 .</data>
<data>15A8 CLOSED-LOOP F/B Post Cranking Inhibit Delay XO2CRK 000A = 5 Sec T/2 .</data>
<data>15AA CLOSED-LOOP F/B Coolant Temp judgement XWTFB 002F = +7 *C T-40 .</data>
<data>15AC CLOSED-LOOP F/B Fuel-Cut check interval XFCUTB 0020 = 800 mSec T*25 .</data>
<data>15AE CLOSED-LOOP F/B Reintroduction Delay after F/C End XFCTFB 003C = 1500 mSec T*25 .</data>
<data>15B0 CLOSED-LOOP legacy XBPRUP 009C = 579 mmHg Bp*760/204.8 .</data>
<data>15B2 CLOSED-LOOP F/B Ev Zone Switching Ev Hysteresis XCLHYS 0008 = 8 Ev% Ev/1.6 .</data>
<data>15B4 CLOSED-LOOP ? 0006 = .</data>
<data>15B6 CLOSED-LOOP F/B City Zone Timer operation XCFBZN 000A = .</data>
<data>15B8 CLOSED-LOOP F/B City Zone Operational Time Limit XCFBCLP 0014 = 10.0 Sec T*0.5 .</data>
<data>15BA CLOSED-LOOP XTHYS 0008 = 0.156 V Vtps*5/256 .</data>
<data>15BC CLOSED-LOOP F/B NTL/MT Integral Gain Zone switch Ev XFBGEV 0038 = 35 Ev% Ev/1.6 .</data>
<data>15BE CLOSED-LOOP F/B NTL/MT Integral Gain Zone switch RPM-LO XFBGNEL 002A = 1312 RPM Ne*8000/256 .</data>
<data>15C0 CLOSED-LOOP F/B NTL/MT Integral Gain Zone switch RPM-HI XFBGNEH 0048 = 2250 RPM Ne*8000/256 .</data>
</table>
</table>
Its a pity the stupid parser strips off the tabs and spaces. The listing looks easy enough to follow with the spacing intact.
ace33joe (Mar 14, 2017)
Old Feb 21, 2017, 06:47 PM
  #79
ace33joe's Avatar
Oh wow! This is some heavy stuffs.
Thanks, Dave. I am not sure if I can understand and use all of these tables, but really appreciate your help. I am sure cold idle gain addition can help my problem!
Thanks again.
Old Mar 8, 2017, 07:03 PM
  #80
ace33joe's Avatar
Dave,
Did a few more logging and fiddling with timing / ISCV / fuel linearization / MAF compensation tables, but still I have rpm fluctuation and rich / lean conditions.
Timing does affect a lot on rpm behavior, and it seems ISCV has minor impact as it only changes one or two steps, so fuel seems to be the major problem.
Did you see any rpm compensating injector pulse adjustment table other than integral gain you already shared?
If there is some "ms" scale adjustment for rpm compensation, it may explain what I am experiencing, but I doubt that is the case.
What still is also mystery is that I see negative O2 feedback trim (like -10~-13%) below 70C coolant temp or so, although I don't think it really changed fuel pulse width I am logging though, then after reaching 70C coolant temp, it works like normal feedback trim (moving positive and negative).
I changed front O2 sensor recently to NTK new one, but it gives me the same behavior as old aftermarket cheap denso O2 sensor.
Is there anything I can try before I change my injectors to different set?
Hope you can give me some advice. Thanks!
Old Mar 13, 2017, 10:13 PM
  #81
merlin.oz's Avatar
Chris,
There is no rpm comp table as you have described.
You will see negative fuel trim as the engine warms once the engine enters closed loop.
This is because you have a warmup fuel enrichment table adding the fuel and then the feedback is stripping it out so the AFR sitts at 14.7.
This fuel trimming is not contributing to a learned value as all this is happening below the learning temperature, which, depending on the rom, will be from 77 to 82 degrees C.
Suggest you raise the closed loop temp to say 45*C for a car with decent cams like yours.
Old Mar 14, 2017, 12:15 AM
  #82
ace33joe's Avatar
Thanks for your reply, Dave.
I also thought about the MAF comp vs. coolant temp table, but that only adds 2~6% of MAF signal, so I thought that is much less than what I see from the O2 feedback trim.
I thought this table exists because of fuel vaporization vs. temp change, but now I think it can also be affected by injector spray pattern and also engine VE / overlap due to cam change.
I think make it open loop until it warms up is a good idea, and my current setting is 30C, so I might try higher temp as you suggested, and I might fiddle with MAF comp vs. coolant temp also.
Is there any other table might affect warm-up enrichment other than these two tables? MAF comp vs Coolant temp #1 and #1?
Thanks again for your help!
Old Apr 4, 2017, 08:34 PM
  #83
Ian0611's Avatar
Is there anyone that would be willing to email me a copy of a known, working XML for 88590015? I've tried pasting the tables into my XML and then reopening ECU Flash several times but the tables aren't showing up for some reason. My email is ianstohr1@gmail.com . Thanks!
Old Apr 6, 2017, 11:19 PM
  #84
Ian0611's Avatar
I got the patching issue sorted out but does anyone know if there are any issues with using this table with a Tephra ROM?
Old Jul 13, 2019, 06:44 PM
  #85
UrbanSmoker's Avatar
Would like to point out the first code is not laid our correctly.
It’s missing < > these symbols at the beginning and end of every table and “data” header. Just fyi cause in doing this now. Probably a fourm bug
even after that i am not seeing the tables show up. using tephra V7 SD 2.0 88592715
Old Jul 28, 2019, 09:51 PM
  #86
Wantthatevo123's Avatar
Injector Small Pulse Correction for Injector Dynamics injectors.
Why use 0.000 for the scaling on the ID2000 and 0.016 as the starting point for the ID1300's?
Old Aug 7, 2019, 08:26 PM
  #87
Knash499's Avatar
Thumbs up
I am also having the same issue, I think the site is working out a bug to get rid of this but if anyone has an xml file with all of the features for 88592715 emailed to k499@hotmail.com that would greatly be appreciated.
Old Feb 29, 2020, 11:01 AM
  #88
unkn0wn.'s Avatar
for 9653:
</table>
</table>
Edit:
try something like:
0.021 to go lean
and
Does anyone know which address this table resides at for the 88590015 ROM? Thank you!
Old Mar 5, 2020, 02:02 AM
  #89
XxOLIVERxX's Avatar
Does anyone know the addresses or even if such table exist in H8 Roms? such as evo 5/6 25570000?
Old Jan 1, 2024, 11:55 PM
  #90
evo10.5t's Avatar
@Merlin, do you have the Closed-Loop Integral Gain Settings for the 88590015 rom? Thanks in Advance
Quick Reply: Injector flow rate linearization table
