Error when trying to flash randomly?! HELP!
So I've had the same laptop, ecuflash ect for years now. I tired flashing a new map on my car today. It was giving me an error message. It wouldn't let me write to ecu or flash to ecu. I heard my USB noise connecting, but the 2 buttons on ecu flash were grayed out!
What could this mean? My battery volt was 11.1-11.3 when trying to flash.
[23:20:13.853] sending init sequence 1 (0001)
[23:20:17.161] sending init sequence 1 (0003)
[23:20:20.468] sending init sequence 1 (FFFF)
[23:20:23.775] sending init sequence 1 (F0F0)
[23:20:26.521] no response to any known code
[23:20:26.521] interface close
yeah i have this issue all the time since my car sits for awhile on a mini battery. i basically have to drive the car a little and the be on the trickle charger to guarantee it flashes safely.
It might be the cable, i just went out and tired it again to charge the battery more. It was reading 14.6-15.2 volts on Evo Scan "so the UBS to OBDII is working fine." Still no luck getting same error code. Super weird it won't let me write from ecu or flash.
If you have an OpenPort 2.0 and your Mitsubishi reflash adapter is damaged, you can contact us at support at tactrix dot com and we can get you a replacement. They aren't listed separately on our site so you'll need to send us an email. We redesigned them about a year ago so they are a bit more robust.
jmcmill3
Nov 22, 2009 12:13 PM
mrfred
May 14, 2008 12:10 PM
