Help finding the correct .xml definition for this 94170015 ROM, No start on reflash
Recently got an Evo8 in that had been converted to SD and tuned by someone in another state, 2 owners ago.
When loading the file into ECUflash, initially very few tables show up.
I poked around and found legacy evo7base and Tephra V5 .xml's, which shows more tables, but many have erroneous values.
Next, I changed the internal ID to 94171715 to be read with Tephra v7 Speed density XML, even more tables show up, but with erroneous values in many more areas.
The reason I want to get into the ECU and re-tune it is because I converted the car back to MAF for the sake of ease and DD duty.
I was able to get the immobilizer code from the file, but when copied to a fresh rom the car will not start at all. (Stock injectors) I am not sure what MAP sensor is on the car, but I have tried stock and Omni 4 bar with no success.
Any help will be appreciated. If you have paypal I will donate for a solution! Thanks!
yucel
Oct 20, 2009 11:04 PM
gunzo
49
Oct 11, 2009 04:52 PM
Chamama
Oct 5, 2009 11:10 AM
