Evo X Intercooler Spray definitions
Old Oct 15, 2015, 09:51 PM
chetrickerman's Avatar
These are not tested, I just defined them. It is up to you to test them, and if something screws up in your car, its not my fault.
52680015
Code:
<table name="ICS Relay Control Min RPM" category="IC Spray" type="1D" address="53dfa" scaling="RPMStatLimit"/>
<table name="ICS Relay Control Water Temp" category="IC Spray" type="2D" address="53dfc" scaling="Temp">
    <table name="Condition" type="Static Y Axis" elements="2">
      On
      Off
    </table>
</table>
<table name="ICS Relay Control Min Load" category="IC Spray" type="1D" address="53e02" scaling="Load"/>
<table name="ICS Relay Control Max Vehicle Speed" category="IC Spray" type="1D" address="53e00" scaling="VehicleSpeed"/>
<table name="ICS Relay Control TPS Position" category="IC Spray" type="2D" address="53e0a" scaling="Throttle %">
      On
      Off
    </table>
</table>
<table name="ICS Relay Control Min Air Temp" category="IC Spray" type="1D" address="53e0e" scaling="Temp"/>
<table name="ICS Relay Timer On/Off Time" category="IC Spray" type="2D" address="53e04" scaling="TimeSec">
      On Time
      Off Time
    </table>
</table>
55570006
Code:
<table name="ICS Relay Control Min RPM" category="IC Spray" type="1D" address="53e0c" scaling="RPMStatLimit"/>
<table name="ICS Relay Control Water Temp" category="IC Spray" type="2D" address="53e0e" scaling="Temp">
      On
      Off
    </table>
</table>
<table name="ICS Relay Control Min Load" category="IC Spray" type="1D" address="53e14" scaling="Load"/>
<table name="ICS Relay Control Max Vehicle Speed" category="IC Spray" type="1D" address="53e12" scaling="VehicleSpeed"/>
<table name="ICS Relay Control TPS Position" category="IC Spray" type="2D" address="53e1c" scaling="Throttle %">
      On
      Off
    </table>
</table>
<table name="ICS Relay Control Min Air Temp" category="IC Spray" type="1D" address="53e20" scaling="Temp"/>
<table name="ICS Relay Timer On/Off Time" category="IC Spray" type="2D" address="53e16" scaling="TimeSec">
      On Time
      Off Time
    </table>
</table>
58010005 &59580004
Code:
<table name="ICS Relay Control Min RPM" category="IC Spray" type="1D" address="53e12" scaling="RPMStatLimit"/>
<table name="ICS Relay Control Water Temp" category="IC Spray" type="2D" address="53e14" scaling="Temp">
      On
      Off
   </table>
</table>
<table name="ICS Relay Control Min Load" category="IC Spray" type="1D" address="53e1a" scaling="Load"/>
<table name="ICS Relay Control Max Vehicle Speed" category="IC Spray" type="1D" address="53e18" scaling="VehicleSpeed"/>
<table name="ICS Relay Control TPS Position" category="IC Spray" type="2D" address="53e22" scaling="Throttle %">
      On
      Off
    </table>
</table>
<table name="ICS Relay Control Min Air Temp" category="IC Spray" type="1D" address="53e26" scaling="Temp"/>
<table name="ICS Relay Timer On/Off Time" category="IC Spray" type="2D" address="53e1c" scaling="TimeSec">
      On Time
      Off Time
    </table>
</table>
I will do more rom id's later
Old Oct 15, 2015, 09:52 PM
Once EvoM fixes their bug problem, you will be able to see the definitions.....
Old Oct 16, 2015, 01:37 PM
merlin.oz's Avatar
Dont hold your breath on that ever happening, its been weeks now so clearly they dont want to do anything about it.
And in the meantime, thousands of hours xml work has been flushed down the dunny!
Old Oct 20, 2015, 07:10 AM
WickWhiteEvox's Avatar
It's view able in the source of the page. There isn't anything wrong people need to use the PHP BBcode.
PHP Code:
52680015
On
      Off
</table>
table>
On
      Off
</table>
table>
On Time
      Off Time
</table>
table>
55570006
On
      Off
</table>
table>
On
      Off
</table>
table>
On Time
      Off Time
</table>
table>
58010005
On
      Off
</table>
table>
On
      Off
</table>
table>
On Time
      Off Time
</table>
table
LiX
May 28, 2013 05:36 PM
Quick Reply: Evo X Intercooler Spray definitions
