omni 4 bar setup?
Okay, so now I've swapped out my OMNI sensor for a new one and I get the same exact readings. I notice that with the ignition on (car not running) it reads less than atmospheric pressure so the sensor scaling is off. I went ahead and did a test and tabulated my Zeitronix gauge data against Evoscan data. See attached screenshot of my spreadsheet, it looks like a linear offset all the way up to 26psi. How do I fix this? I suspect it's my X-axis scaling on my MAP based load calcs tables? I've also attached a screenshot of those. I attached a screenshot of Tuner Helper's screen too because it tips me off that I should be looking for an X-axis scaling that ends with 34.98, but I don't have any scaling in my XML that gets me there... I'm expecting a scaling like "Omni4barMAP in psig" but I don't have any such scaling.
Hi, I download your ROM and had a look. It seems you missed out 2 additional steps in enabling the Omni4Bar usage. You enabled the 3 patches but missed out the X axis changes for the MAP based Load Calc and Fuel Compensation MAT vs MAP tables.
It seems like your axis are still wrong. Probably didn't have the right scalings in your definition files.
Maybe you can PM me with your email address and I will send you the modified ROM to flash and test.
Fuchsig
Jan 11, 2015 03:20 PM
