ECUFlash Unknown ROM Image
Hello,
I'm pretty new to tuning etc, just learning at the moment.
Quick background: I have a relatively performance modded 2013 Ralliart Lancer AUS (HFC, IC/UICP/LICP, three port, hi flow air filter) and it has been ECU tuned already, the process of the tune interested me so I'm seeing if I can learn it myself.
After ripping the ECU with ECUFlash, I receive the error 'Unknown ROM image'. I understand that means I do not have the required definition XML files to interpret it.
Attached is the ECU tune, can anyone here help provide the required definition file?
I started reading about importing tephramod v7 but I became a little lost.
Also since it's already been ECU tuned, how could have that changed the ECU file?
Thanks in advance!
Thanks in advance!
You are posting this question in the wrong place. Please repost in evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Apologies, I think i worked it out anyhow.
used a ROM and XML file from https://www.evolutionm.net/forums/ev...raxmod-v1.html.
