Can I simply disable EGR via EcuFlash?
Old May 13, 2016, 06:17 PM
breadn56's Avatar
Can I simply fully disable EGR via EcuFlash?
Hey guys I have a Evo IX and have done a few simple things with Ecuflash like updating the ROM version and force passing OBD-II checks to pass emissions. I have been having bad idle issues and recently the CEL code P0401 came up which seems to be a common EGR problem and caused the exact idle issue I am having for a few other people with a Evo IX.
My question is instead of trying to fix my EGR or remove it from my car can I simply change some stuff with EcuFlash and disable it completely with no coldstart / idle issues without adding / removing anything from the engine bay?
Old May 13, 2016, 07:21 PM
edsct9a's Avatar
Did the idle issues start when you switched roms? What rom did you switch to? Have you checked to see if 2 small hoses have came off the EGR which are somewhere under the TB?
Old May 13, 2016, 08:02 PM
breadn56's Avatar
Sorry I wasn't specific about that but when I did anything with Ecuflash was at least 4-5 years ago and the idle issue just came up kinda recently and I will check if any plugs came off but just in case there are none I heard someone else had to replace his EGR to fix the same issue as me(not sure if this is true) so wondering if it's as easy as turning it off in Ecuflash without adding or removing anything physical in the engine bay to stop any issues with it.
Old May 13, 2016, 08:43 PM
05EV08's Avatar
I would buy a block off plate and then remove the valve and then disable from ECUflash. I don't think you can just disable it and be good to go. Someone correct me if I'm wrong though?
Old May 14, 2016, 07:42 AM
breadn56's Avatar
Thanks ! This is exactly what I needed to know so if someone could just confirm this for sure that would be great.
Old May 14, 2016, 07:04 PM
hutch959's Avatar
block off plate......
correct.
JKX
Jul 28, 2016 01:01 PM
hediki12
Nov 21, 2012 09:40 AM
211Ratsbud
Jun 29, 2012 01:24 PM
evane
Apr 2, 2009 10:14 AM
shangai
Dec 8, 2008 04:22 PM
Quick Reply: Can I simply disable EGR via EcuFlash?
