Need help with RomID and XML... PLEASE :(
Old Jul 19, 2016, 07:57 AM
mindfreakattack's Avatar
Good day, i just bought a JDM 08 Evo X GSR. And i cant seem to find the xml for my ECUFLASH to work correctly. Can any kind soul please help me?
File Type: zip
Old Jul 20, 2016, 06:39 AM
really no one willing to help me ? anyway... what will happen if i just open up the base XML of a JDM 2008 EVO X and edit the name of the ID to my 84802379? will it work?
Old Jul 21, 2016, 06:44 PM
afdah's Avatar
I wouldn't do this if I were you. You will have a high risk of bricking your ecu due to flashing a bad rom.
This rom is not stock. Meaning your car has been tuned and flashed before and whoever the tuner is, he or she changed the ROMID to make it more difficult to tune.
Old Jul 22, 2016, 06:33 AM
splattj's Avatar
The ROM file you posted is incomplete or corrupt. Try downloading/uploading it again and I'll take a look at the HEX data.
Otherwise, open your ROM with ECUflash. You will get an error that says "Unknown Rom Image". Instead of selecting "abort using this rom image", select "Use wizard to create a new definition", then click "Next"
It will give you 3 options to choose from, select "Inherited from definition below", then in the pull down menu, select a definition (like evo10base, or another evo 10 definition (must start with either 5268, 5269, 5557, 5558, 5559, 5689, 5690, 5801, 5802, 5957, 5958, 5959)), then click "Next".
In the next screen that comes up, there will be a box on the bottom half that says "Identifier". Inside that box will be your rom ID.
Once you have your ROM ID, quit without saving anything and you should be all set.
Old Jul 25, 2016, 05:17 AM
tephra's Avatar
it's 523600xx... probably 18 at the end..
you can edit 0x5002a, and make those 4bytes 52360018, then it should open ok in ecuflash..
and if things dont look "right" then dont edit/save/flash
Old Jul 28, 2016, 09:18 AM
Hi tephra... how do i change the 0x5002a, and make those 4bytes 52360018 ?
Old Jul 29, 2016, 06:23 AM
tephra's Avatar
get a hexeditor?
ultraedit or hexworkshop should do..
you need to jump to 0x5002a (ie the address in the file), and change (NOT INSERT) the 4bytes there to be 0x52360018
Old Jul 29, 2016, 09:32 AM
weird... !! i used hexworkshop to open up my rom.. and i cannot find the add of 5002a... any reason for that Bro Tephra?
Old Jul 29, 2016, 06:24 PM
tephra's Avatar
open the file in hexworkshop
press Ctrl-G
type 5002a, select hex, hit Go
change the 4bytes
save
open in ecuflash, say ok to the checksum error
check out the available maps to make sure they "look right".. that will indicate whether you have used the right ROMID or not...
Old Jul 29, 2016, 07:01 PM
Hi Tephra, the funny thing is, i cannot find the addresss 5002a i closest address i can only see are 5002D, 50014 etc...
Old Jul 30, 2016, 05:42 AM
tephra's Avatar
dude - you taking the ****?
follow what i wrote
Old Jul 30, 2016, 09:11 AM
Sorry bro... i'm not trying to **** you off... but i did exactly what u told me to... and this is what it shows me....i cant seem to find 5002a
Old Jul 30, 2016, 05:23 PM
tephra's Avatar
ok... to make it "Easier", click options -> preferences -> display options -> general, then untick "Fit contents to window" and make sure the text box below says 16...
you can still edit 5002a with the default settings, but it makes it a bit harder to see it...
Old Nov 7, 2016, 07:08 AM
nikush's Avatar
my rom is 52360022 2007 JDM evo 10. Can't find definition for it((((
richardjh
Apr 19, 2015 05:52 PM
E6-X
Jul 29, 2010 04:21 PM
KazzEvo8
Aug 20, 2008 12:26 PM
tephra
Dec 21, 2007 07:43 AM
RoadSpike
Oct 7, 2007 12:19 PM
Quick Reply: Need help with RomID and XML... PLEASE :(
