ELM with 88590715 issues
Hello, im new to evolivemap app, but i played with it in past few days.
Car is EDM IX with 88840016, flashed tephra 88590715, patched by ELM and just immo off and TPS map switching modified. I can realtime change ignition advance and injector size, but cannot fuelmap values. Map is read from ram ok, same as i see it in ecuflash, make a change -> status bar note succesfull write, but no change in fuelling.
Second issues are this, when i applied patch, gives this note:
"Please note that additional maps have been moved to ram, this means you will need to update your Ecuflash defination with the new addresses given below
MAF Smoothing/Compensation = 49B28
Injector Latency = 49B02
MIVEC Intake Advance = 4A30B"
but when i add them, i see corrupted values, like adress is wrong. I dont need to change these in realtime, but these are new "alternate" tables? I want to change injectors and intake pipe, so i must touch latency and maybe compensation, so i dont know, when i do not touch these new tables, will ecu use "normal" latency + smoothing for alterante map also. I understand these are new from last versions of ELM => what if i patch a file with older version to avoid creation of these maps?
And last issue, in old version (i see only pictures) there was short fuel trim by O2 sensor, there is a request named 02trim , but showing wrong(jumping randomly in negative, even engine not running). Is it normal?
thanks
thanks
