Help from the GURU'S MODE23 on MIRAGE 2014
Old Mar 8, 2017, 05:29 PM
Hiram6g74's Avatar
Exclamation Help from the GURU'S MODE23 on MIRAGE 2014
I finded 2 tentative mut tables on this rom and already make the evoscan definition for mode 23 but !!!!
Idk how to find the do mode 23 switches on the rom. can anyone would give some help please ?
here the rom and the definition
Evoscan Deff
Code:
<ecu name="Mode23 2015 USA MIRAGE">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="N" Color="" Display="RPM" LogReference="RPM" RequestID="23F8A2F0" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.01" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load (Fuel)" LogReference="Load" RequestID="23F8A300" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="340" ChartMin="0" ChartMax="340" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Timing Advance" LogReference="TimingAdv" RequestID="23F8A290" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="BoostPR @80F/300m" LogReference="BoostPR" RequestID="23F80AC8" Eval="(x/4*0.1953125)- 14.53" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23F807C0" Eval="x*1.000001" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="AFR" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="10" GaugeMax="16" ChartMin="10" ChartMax="16" ScalingFactor="1" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="AFRMAP" LogReference="AFRMAP" RequestID="23F896A8" Eval="(14.7*128)/x" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Engine Coolant Temp (ECT)" LogReference="ECT" RequestID="23F89544" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp (IAT)" LogReference="IAT" RequestID="23F8A318" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="23F892A3" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Battery" LogReference="Battery" RequestID="23F8A314" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        </Mode2>
    </ecu>
File Type: bin
File Type: xml
Old Apr 13, 2017, 08:59 PM
lexa609's Avatar
Hello!
ht tp:// projectlancer . net /forums/topic/19080-finding-rom-id-and-enabling-mode-23/
newcomer81
Sep 26, 2020 05:17 AM
Kishin
Jul 28, 2017 10:20 PM
darksideauto
Lancer Engine Management / Tuning Forums
Jun 13, 2012 05:38 PM
LVSBB6
Oct 23, 2009 10:23 AM
Quick Reply: Help from the GURU'S MODE23 on MIRAGE 2014
