Can anyone look at my logs and help me out - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
EcuFlash
Sponsored by:
Sponsored by:
Old Apr 17, 2017, 01:10 PM
Evo_Goodness's Avatar
So long story short when i do a first pull i get knock not high counts never over 3/4 its most of the time around 2 counts to 3 but its constant but then i can log 10 more times in a row and get no counts am i over thinking something here lol...
I cant figure out why i get my first log with counts of knock then no more logs show it after that has anyone seen this ill post both logs so people can look them over
I know i don't have boost showing or A/F but they are inline at spool up i'm seeing 12ish and full and as i go into full boost it tapers to 11.4 give or take a point each direction thats at 21PSI tapering to 18PSI.
I cant log 2 byte yet waiting for my omni 4 bar to show up
Mods are DW200 fuel pump
injen upper lower IC pipes
Injen CAI
stock injectors
stock turbo
Evo_Goodness is offline
Old Apr 17, 2017, 01:11 PM
PS i also did 4 more runs after the one showing no knock and it was the same 0 counts of knock
Old Apr 18, 2017, 12:22 PM
Any one have any ideas ? Beginning to wonder if it phantom knock
Old Apr 18, 2017, 01:08 PM
Abacus's Avatar
If you want to rule out knock then you should schedule some dyno time and see exactly what the timing gains/loss is. A dyno session is cheap compared to bigger problem . Road logging with a single knock sensor and hobbyist software can only be so accurate..
Timing Looks to high . These engines don't need alot to run. A ramp from 0-3 on the hit and work up to 12-14 should be a good ballpark on most fuel.
They really don't need to hit 19-21 out the top if your log is correct. This isn't a game on trying to pack as much in as possible to try and win.
Less is actually more in the long run.
Abacus is offline
Old Apr 18, 2017, 01:14 PM
letsgetthisdone's Avatar
What fuel is this on? Pull 4-5* out of your timing map, minimum, to start. Too much timing in that. Like Abacus said, at the hit you should have about 0*, ramp it up to 3-4 degrees at 5k, and then only revving to 7k, you should be seeing 12 up top. If you take it 8k, maybe 13 or 14*. With that timing, you can run more boost, like 24-25psi on the hit, and let it taper up top because it's a stock turbo.
letsgetthisdone is offline
Old Apr 18, 2017, 01:37 PM
Oregon 92OCT here's the funny things it's still on the stock timing map lol I haven't messed with it yet but I guess it's time to start my AF where way lean at WOT because the stock fuel pump was dying
Old Apr 18, 2017, 01:39 PM
The stock timing map is too much timing for any American pump gas.
Old Apr 18, 2017, 02:11 PM
Well then lol you learn something new everyday guess it's time to start pulling timing should I pull 4/5 degrees across the hole map and then work on it from there or.? Or should I start removing timing from those sections and work off of it from there ?
Old Apr 18, 2017, 02:17 PM
I would do the whole map, from like 120 or 140 load and up. And then work on smoothing it as well. You want a larger jump that 2-3 degrees with load change of 20, and no more than 1-2 for an rpm change of 500rpm
Old Apr 18, 2017, 02:22 PM
I'll try to put up a pic of a reasonable starting point for timing when I get home
Old Apr 18, 2017, 03:21 PM
If you would that would be awesome man I could really use a good point to start with
Old Apr 19, 2017, 09:55 AM
Pic fail
Old Apr 19, 2017, 09:58 AM
This is NOT an English Racing timing map. This is someone else who I no longer use.
I would take this map, and highlight the 120+ load for all RPM's, take 3-4 degrees out, and give it a try. Watch for knock while you're making a pull. If you have a stock ROM, you won't have this much resolution. You also won't need it. And then look for your logs to look like how Abacus and I mentioned the timing curve should look like. Remove or add timing as needed.
Old Apr 19, 2017, 11:50 AM
Thank you very much I'll tinker with it tonight.
So pretty much start at the 120 load and pull 3/4 degrees and across the full rpm range so starting at 500 all the way to 8k and log then smooth it from there hope I got that right lol the fuel map was a lot easier to get smoothed out lol
Old Apr 20, 2017, 10:38 PM
That map is already smooth. Just drop it down, and see what you're hitting.
Quick Reply: Can anyone look at my logs and help me out
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
