EVO X MR - TephraXMOD V3 - launch map - altmap
The launch maps don't work out of the box for an SST car. Lots of thing with ignition timing and shifting don't work in SST cars either, that doesn't have anything to do with the patch. Having a patch that cut an defined amount of timing above a defined load on shift would make life for these cars much better. I can confirm that the factory timing tables for shift have some very polluted logic that makes them useless. If anyone wants to code something like this that works for me, send me an email. I will pay $$$$.
Eric@kozmicmotorsports.com
Justin
Working with a friend to figure out the patch to enable launch maps using the brake switch on v3 for the sst cars
Edit: if anyone has a 2010 mr usdm with v3 and is will to test pm me
GP148 (Jul 1, 2017)
GP148 (Jul 11, 2017)
Has anyone had an issue with the launch maps not interperlating 100% correctly ( i.e the launch timing maps). I can say for a fact that the maps are taking affect, as previous to the brake pedal switch, my timing was around 22-25 deg. wit the tables set at -10 deg at the appropriate load, it is only hitting 2 deg. Seting the same target load/rpm area to -15 didnt alter the actual timing achieved. Am I missing anything? Could the fact that i have added more fuel in the same area on the fuel launch maps affect the timing achieved? (as in the car will only advance the timing so much if the mixture is x rich?) Has anyone else had the same experience with this mattter? Here are my Launch maps for an sst (56920008)
here is a log of it ( still builds 10psi, but was looking for just a little more pop
Sorry to bump an old thread but, does the launch maps make the car easier to launch since it’s not using the factory LC? Or would I still get the overheat warning if I don’t launch super quickly?
