Attempting to tune my bucket of bolts..
My XML is attached. That table you show is currently set back to the stock 8 deg.
I had the idle timing set to 8 degrees and the stability control set to 4, but it didn't seem to make any difference so I just changed it back to stock values.
Do you think I should set the timing cells up to 1500rpm to 5-8 degrees. Rather than the stock 5-19 or whatever it is?
Sorry for the crappy pics I'm doing this from my phone because my laptop has no internet connection right now.
Now I'm seeing your maf comp is not responding to major changes, you might want to consider reloading your rom or changing to an evo 8 rom. They have some patched 8 roms that work with evo 7's. You will have a lot more options with 9653.
luckybull
10
Feb 12, 2011 08:18 PM
sbpwjm
26
Oct 4, 2007 06:56 PM
bxthai
36
Nov 1, 2006 09:54 AM
