Help Identifying Maps
Noob question. 03 GSR. Tuner won't help and don't have an AFR gauge.
Put 2 maps on my car: E54 and 91. Went to switch from E54 to 91 via flipping the key to the on position and holding down the gas pedal. Check engine light flashed. The intercooler sprayer light is supposed to light up signaling a map change. Mine did not light up. I just want peace of mind to see what map the car is on. Is there a way I can plug in my tactrix cable and download the ROM on ecuflash to see what map it is?
i think you're activating the Valet mode via the gas pedal?! Try using the IC spray switch to switch maps.
otherwise yes, you can read your Rom and figure out what settings/how the alt map is activated.
happpy to help out if you grab the Rom.
^^ I'm pretty sure that link will work. Not sure if I downloaded the rom correctly though. Let me know if it works. Thanks for helping.
Please get an AFR gauge, it is one of the basic things that you need to have in the car which is tuned and modded. It will help you identify alot of problems and determine if the car is running ok or not.
Yep worked.
So looking at this. Your main map is your Eth map. Alt map is your pump map.
you were right in using your gas pedal to switch between maps, but the second highlighted cell indicates that the IC indicator is not switched on. change that to a 1 and write the map to your car.
Slow flash os main map.
Fast flash is alt maps i.e e85
And its done with gas pedal.
Well usually. You need a wideband or your just blindly driving the car.
aiden1983
Cobb AccessPORT
756
Aug 12, 2014 04:37 AM
