EvoScan Logs Missing Data
Old Nov 1, 2017, 11:51 PM
ZMX
ZMX's Avatar
This issue has me stumped, and I'm not sure where to begin in fixing it.
EvoScan can see wideband data, and had been logging it perfectly.
It can still see wideband data, but as of recently, no longer logs it.
Below is a picture showing the wideband's live data as visible, and the log with blank cells in Excel. MegaLog Viewer HD also shows no data in these new logs. The live values shown in EvoScan match the wideband's live reading on its gauge. It's connected via serial port.
Help would be appreciated. Thanks.
Old Nov 2, 2017, 08:08 AM
4b11slayer's Avatar
Make sure that thewideband port is correctly selected.
Is it a serial wire or how did you run the data to ecm
Old Nov 2, 2017, 10:57 AM
ZMX
ZMX's Avatar
The wideband is connected by serial port.
When logging, EvoScan shows the wideband's live data, and it does agree with the readout on the gauge itself.
But, it just started not recording the info into datalogs after saving several that did work throughout the day.
Old Nov 2, 2017, 11:06 AM
4b11slayer's Avatar
Ahh i see so it reads live data but doesnt log it. Try setting a different communication port.
Old Nov 2, 2017, 05:46 PM
ZMX
ZMX's Avatar
The problem has gone away.
I'm not sure how it was caused, or how it was fixed. I didn't change any settings recently before or after it started.
Old Nov 2, 2017, 06:02 PM
4b11slayer's Avatar
Likely a electronic hiccup.
jogi_rm
Sep 18, 2014 03:52 AM
jogi_rm
Sep 17, 2014 10:33 PM
EriCS
Sep 6, 2013 06:34 AM
Jim in Tucson
Mar 24, 2008 07:47 AM
Quick Reply: EvoScan Logs Missing Data
