read codes or log ABS on usdm evo9 with evoscan
Old Nov 24, 2017, 02:11 PM
waynea's Avatar
Has anyone been able to log or read/reset trouble codes in the ABS computer on a USDM evo9 with evoscan. Is there anything else besides a mutiii that works?
I have been trying with an openport 1.3u with pin 9 pulled on a windows 10 laptop will no success.
Thanks.
Wayne
Old Jan 2, 2018, 07:01 PM
ladiesman285's Avatar
Bump also interested in any leads to this question.
Old Jan 3, 2018, 10:48 PM
foxbat's Avatar
I also wasn't able to read DTCs on the main ECU using evoscan 2.9, openport 2.0, JDM Evo9 GT!
Old Jan 14, 2018, 08:19 PM
Well I found a way to read ABS codes on EVO 8 and 9's without a MUT III Mitsubishi Scan Tool.
Several generic scan tools I used were not able to access the ABS codes.
It's rather rudimentary but it works and is actually documented in the ABS service manual.
Simply Bridge Pins 1 and 4 on the DLC (OBD-II) communication port. I used a paperclip with the vehicle running (should work with vehicle not running too). This will cause the ABS light to flash in a coded way that allows for two digit codes to be deciphered based on the flash length.
The number of long flashes correspond to the tenth place and short flashes correspond to the ones place for codes. The ABS service manual has a table that allows you to look up what each double digit code means.
Source: http://www.lancerregister.com/showthread.php?t=422067
Hope this helps somebody.
Th3BigIII
Feb 1, 2016 02:53 PM
740 Turbo Brick
Nov 25, 2012 01:11 PM
fireroasted
Dec 15, 2011 02:24 PM
HiRevnVIII
Mar 1, 2010 05:58 AM
UndieStainz
AEM EMS
16
Sep 28, 2006 03:50 AM
Quick Reply: read codes or log ABS on usdm evo9 with evoscan
