53050012 Logging
53050012 Logging
Hello guys,
Logging with evoscan version 2.9.0100 gives random false values no matter what the logging method selected .
Mode 23 enabled correctly
Can someone please advise how to do it ?
I'm now on 53050312 = Tephra V3
I've installed RAX3 fast logging REV E and even though the logging is not working.
Can someone from the forum gurus give support to this matter ?
Logs attached.
With the Mode 23 the values are wrong and the response is slow.
With the RAX fast logging some of the values are correct and the response is extremely slow.
P.S: with live tuner logging everything is working but it I Like to use the evoscan
I appreciate your comments.
Thanks
Thanks
Care to upload your ROM? I think mode23 is not enabled.
For RAX logging, you got 27 sampling per sec, which is rather slow (I got 56 sampling per sec). As razorlab suggest, probably try to reinstall Evoscan and Tactrix drivers.
Good luck!
Good luck!
Please check the attached photos and give give me your opinions.
As for the evoscan I had the same doubts, so I uninstalled it deleted the linked folders and the reinstall it but with the same result.
I didn't try to uninstall the tactrix drivers or update them, I will try this and see the result.
P.S: I had the same issue with 53050012 and the tephra V3 53050312
Thanks
Thanks
I am trying to understand your comment that "the response with Rax is extremely slow"
Looking at your logs;
Rax - In one second you have 25 rows of data for 35 different parameters (columns)
Mode 23 - In one second you have 32 rows of data for 9 different parameters (columns)
If you had logged 35 different parameters with Mode 23.. you will have alot less data per second to work with right?
I have experienced 17 rows of data for 35 different parameters while logging a SST but that was still alot more data to work with than using Mode 23.....
Just trying to understand where you are coming from.........
did u solve this?
im having same problem with 53050312 tephrav3.
Tried enabling mode23.
logging is always messed up.
can works but cant log trims nor knocks...
its been a decade since i last tuned an evo so im pretty much a noob.
HELP
I have sold my evo a year ago and to to be honest I completely forgot how I was logging it.
Sorry ..
