flex fuel for evo 8 what pin do i connect analog output?
It depends on which flex fuel ECU patch you are using and which version of the ECU you have. For example, if you are planning to use AST's FreeFuel ECU patch it uses an analog DC (0-5V) input connected to the ECU pin that is used for map switching:
- Evo 8 4-plug ECU: pin 42
- Evo 8 3-plug ECU: pin 64
For a more useful answer let us know which ECU you are running, which ROM ID, and what sensor and signal converter hardware you are using.
R33E8
Mar 23, 2017 05:09 PM
kiddsm95
Jul 29, 2014 07:30 PM
evolv
10
Mar 3, 2010 02:09 PM
