Tuning help for Evo 9
Old Mar 8, 2018, 03:02 PM
ROGUE DSM's Avatar
Need some help with tuning bolt on parts to my Evo 9 stock map. What value/tables needs to be changed? Looking for some pointers and tips for someone who’s new to tuning. Below I listed my current bolt on mods anything that’s not listed is stock otherwise noted. Thanks in advance
2006 Evo 9 mr 6 speed
- upper intercooler piping
- intake with AEM air filter
- Mishimoto Lower intercooler pipe
- stock intercooler
- MAP performance header manifold
- Invidia O2 housing
- Invidia down pipe
- HKS exhaust system
- EVO 9 turbo
- stock WGA
- stock injector/fuel pump
Old Mar 8, 2018, 03:38 PM
seeaich's Avatar
have you read merlins PDF and watched recompile's youtube series?
Old Mar 8, 2018, 08:56 PM
RightSaid fred's Avatar
Non of those things will do anything for performance.
Not unless you turn up the boost but even then they won't do much and there's no tuning required.
Old Mar 8, 2018, 11:14 PM
2006EvoIXer's Avatar
Reinstall your stock air box. The cold air is good for 400 hp and sucking hot air will lose you power. As for exhaust, are you running test pipe, stock cat, or high flow cat? You should spool faster and be able to increase boost slightly. GL and don't blow your engine!
Personally, using stock air box and snorkel (and drop in filter), I think you can get 320 whp on dynojet at 24 psi and HFC on a good tune. Maybe 330 whp with test pipe.
Kevin@MellonRacing
EvoX 'For Sale' Services
Aug 12, 2009 08:41 AM
Kevin@MellonRacing
Jul 14, 2009 12:58 PM
AbrasEvo
Apr 18, 2009 10:01 AM
COBB Tuning
Mar 16, 2009 03:07 PM
longhornman
Nov 6, 2008 01:47 PM
Quick Reply: Tuning help for Evo 9
