EcuFlash
Unknown ROM - Ecuflash
Old May 21, 2018, 03:55 PM
1hotevo9's Avatar
Liked 0 Times in 0 Posts
I am also getting this UNKNOWN ROM error when trying to open 2 different HEX. rom files i read from two evo 8 ECU's, used a 1.3 cable and evoscan to download them.
I have the tephra v7 XLM file in Rommetadata>Mitsubishi>Evo and all the other XLM files that came installed
So i think need help finding the right definitions for these 2 files.
The first ecu was in a 2003 Evo 8 USDM and the second was bought used and tested using this evo.
Also I have a evo 9 with a tephra map and i can read it so i don't think these are tephra maps.
.Thanks in advance.
P.S.
A pic of just the USDM definitions im using.
1hotevo9 is offline
Old May 25, 2018, 04:47 AM
Boost Demon's Avatar
Liked 7 Times in 7 Posts
Add the Tephra Evo 8 ROM to your list and you should be good.
Boost Demon is offline
Old May 26, 2018, 10:35 AM
1hotevo9's Avatar
I know it's not in the screen shot but I do have the evo 8 tephra map in there and I still can't read these 2 maps. If anyone can read theses maps let me know.
1hotevo9 is offline
Old May 28, 2018, 02:31 PM
cdrinkh2o's Avatar
Liked 38 Times in 33 Posts
Evo8_2_FlashImage_20182005_2259.hex has a ROM ID of 96531706. You will need to add the 2D SD 96531706.xml to your Ecuflash metadata directory to open it.
Evo8_FlashImage_20182005_2256.hex has a ROM ID of 94151715. You will need to add the 2D SD 941715.xml to your metadata to open it.
cdrinkh2o is offline
Old May 29, 2018, 02:30 PM
1hotevo9's Avatar
Hey thanks,
I Searched and I find a tephra definitions update pack I download it put the XLM files and everything opened just fine.
1hotevo9 is offline
kambodianboi
EcuFlash
23
Nov 15, 2018 09:30 AM
duranvw
Sep 20, 2015 07:46 PM
plastus
Aug 4, 2015 07:59 PM
mynew03evo
EcuFlash
15
Apr 30, 2014 09:18 PM
babaz7
EcuFlash
Nov 24, 2012 07:16 AM
Quick Reply: Unknown ROM - Ecuflash
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
