AEM 5 Bar Setup
AEM 5 Bar Setup
Im using 96530706 Rom.....which tables do I need to change when switching from Omni 4 Bar Map to AEM 5 Bar? I am drawing a complete blank here. Also, I believe I should use the kPa Kavlico5BarMap scaling? the thread i found makes no mention of this ROM....only the others.
Boost Desired Engine 'PSI'
Boost Adder (PSI)
Boost Error Correction (PSI)
Search is your friend http://bfy.tw/LWor
Alternate Boost Desired Engine 'PSI'
Boost Adder (PSI)
Boost Adder (PSI)
That does't answer his question. Instead of being a smart *** you should have concentrated on reading his question correctly.
You only need to change the map sensor scaling table (Volts vs KPA), But you need to have the correct scaling value for the AEM 5bar. I wonder why are changing the Omni 4bar? I tend to use the Omni 3 & 4bar, their scaling values are usually included in the packaging.
SBR INC
13
Jun 18, 2010 11:57 AM
SBR INC
Evo 'For Sale' Electronics / Lighting / Audio
Mar 23, 2010 06:26 AM
2JZfan
10
Aug 20, 2009 11:38 AM
InjectedPerformance
84
Jun 29, 2009 12:33 PM
