Take a look at this...
Hey guys, so ive been trying to tune the car. I'm a beginner at this. Car is an 04 evo 8 with gsc s2 cams, evo 9 turbo, stock injectors, full bolt ons. I'm getting some knock down low and I cant get rid of it. I think the timing map, fuel, and ve maps are pretty conservative. Can someone please take a look at this? Maybe its not real knock but how can I tell? I still haven't made a wot pull but up top is really conservative. Also, when cruising have a little lean spot around 3k or so rpms where afr will start getting richer then go leaner then come back down as it gets into boost if that makes any sense. Maybe this could be the culprit idk. I will put up the rom and last log.
