high rpm knock on transistion from low to high throttle, fuelling not keeping up
Folks, I have been struggling with this issue at the track for a few years and really need some help. I'm in oz.
The car:
I have an Evo 8 (jdm) with an gsc s1 cams, evo 9 turbo and bosch 1000cc injectors running 96530706-v7 rom running 93oct (us).
The problem:
When I back off at high rpm or even on gear change, then go full throttle, the boost builds quickly but the ipw does not keep up causing a lean situation despite reduced high load low ignition timing.
This causes knock until fueling finally catches up and I return back to my fuel map's 11:1 cells.
Have tried:
1. reducing timing + adding fuel (made more boost quicker and didn't work)
2. upping synchronous enrichment (1.5 -> 1.6, didn't work)
3. upping asynchronous tps enrichment (didn't work)
4. upping maf compensation (hmm, not sure if helped)
I have attached screenshots of my timing, fuel, log snippet illustrating the issue.
Hoping someone might have some tips on this.
The car:
The problem:
Have tried:
No problem with walbro 255 pumping fuel, I consistently get low 11:1s at full loads.
It's the tip in, instant boost at high rpm from small evo 9 turbo. Ecu load sampling seems too slow to adjust.
This wasn't an issue with my previous 9366x rom, just the 9653x rom.
I want to keep the 9653x rom because it has more maps defined that I can tune startup/idle better with my 1000cc inj than mostly undefined 9366x.
