EcuFlash
Afr going richer gear by gear
Old Oct 5, 2018, 11:40 AM
i everybody, i have an very strange problem with my tune.
when i do a pull in 2. gear it goes about 12,5 then i flatshift to 3.gear it goes 11.5 then 4. 10,5
i'm aiming for what it does in third gear 11,5-11,8 ish
what the hell is going on here :P
is this a simple noob error ?
i have attached the log
9:1 compression ams intake stock turbo and injectors. (and yes i know the injectors is maxed out new is on the way)
Michael Jensen is offline
Old Oct 5, 2018, 11:45 AM
razorlab's Avatar
Turn off lean spool
razorlab is offline
Old Oct 5, 2018, 11:48 AM
is turned off
*edit* i think it is, its set to 8000rpm enable or is it necessary to find the bit that disables it ?
Old Oct 5, 2018, 11:58 AM
razorlab's Avatar
Originally Posted by Michael Jensen View Post
is turned off
You have to disable it all together or change the lean spool target afr table to not richen over time. Easiest is to fully disable it.
However know you will have to retune your fuel table once you disable lean spool
razorlab is offline
Michael Jensen (Oct 5, 2018)
Old Oct 5, 2018, 12:07 PM
Ok thank you didnt know there were over time modifier also.
i'm running tephramod with rom 88580714
i have found under ecu periphery1 FBA bits bit 0: lean spool,
is it just this bit i have to set to zero ?
Old Oct 5, 2018, 01:07 PM
razorlab's Avatar
yes turn the bit off.
The table I was eluding to is this one:
This is after someone changed the values to match. OEM they are richer. Which causes the effect you are seeing.
razorlab is offline
Old Oct 5, 2018, 01:29 PM
Okay thank you i will try this in the weekend. 😁
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
