unknown rom 88596715 evo 9 usdm.
Hello bought the car with cold start issue try to fix my self read ecu with ecuflah its unknown rom id 88596715 add every single xml file to evo folder but no luck. i will apricitae if any body got xml file for my rom i will appreciate and donate if have to thanks.
Rom attached.
Thanks
Rom attached.
Thanks
Hey some questions. Is your car SD? I think someone edited the hex rom I'd.
88590715 usdm v7 rom.
you'll need to do a little foot work but if that's the case a hex editor will allow you to edit the rom id.
I used 88586714 which was a sd2.0 live map edm rom but has no usdm equivalent.
