Unable to Read/Write using ECU-Flash
You said this is a new Tactrix Openport 2.0 device. I also see you have an Evo IX which is a non-CAN interface device.
Did you download the appropriate adapter?
The Tactrix site states a re-flash adapter is needed for Evo 9's
For Mitsubishi, you'll need the adapter for most pre CAN vehicles which include the 5-9 Evo.
Choose the adapter you need from the 'Reflash Adapters' drop down list on the right side of this page.
This is a common issue with Ecuflash and Evos V, VI you have to press read / write wait for the OK popup window turn your key quickly to ON position and hit OK that works for me in a couple of EVO's with read / write issues. Just give a try
what kind of cable are you using? Openport 1.3x 2.0 etc?
Cables go bad, I've had to replace my broken evoscan 1.3u and repair my openport 2.0.
Try the following procedure:
Start the engine, let it run for about 5 seconds before pressing the read Button and the OK Button. The engine should be switched of by itself then and the read starts. IF that doesnt work, check that the Read Write Pin in the white connector ( Car Harness side ) is in the right position. Some Tuners changing the pin position for Read write inhibit, but Logging is working this way. ( matching the position of the female pin in the Reflash Tactrix adapter )
Sorry for no response. Had to take a break from the Evo for a few days. Got pretty frustrated.
Do you have a diagram of the pin positions? By just taking a look at it, it looks like it's never been altered.
Yeah. Correct ECU has been selected this whole time.
Do you have the right ECU selected in the drop down?
If you have the 03-05 selected you get a similar error.
