-   EcuFlash (https://www.evolutionm.net/forums/ecuflash-179/)
-   -   Speed Density Idle problem ( 70 LOAD- 10.5 AFR ) (https://www.evolutionm.net/forums/ecuflash/728622-speed-density-idle-problem-70-load-10-5-afr.html)
EvilEvolution8 May 10, 2016 01:45 AM
Hello Guys,
After 5 days my Evo 8 with speed density running!
Car running at idle with 70 LOAD(95Hz airflow) instead 30, and 10.5 AFR instead stoich.
What's wrong? Seems needs a sort of calibration MAP -> LOAD ?
pisyakot May 10, 2016 05:22 AM
maf load = sd load, check you calibration
EvilEvolution8 May 10, 2016 06:02 AM
1 Attachment(s)
This is my sd ve table.
Any suggestions?
Evo9_Dubai May 10, 2016 06:32 AM
I am not a professional nor a tuner, although your RPM VE seems a bit rich on the idle.
ridenrunwv May 10, 2016 11:55 AM
Just noticed that you said after 5 days like this was a problem that just came up after 5 days of running differently on the same tune? If that occurred you might have a mechanical issue.
EvilEvolution8 May 10, 2016 11:58 AM
Any suggestions?
Ohh no sorry! 5 days to male a conversion...today is a first day that i run with SD :)
ridenrunwv May 10, 2016 12:01 PM
Try RPM VE 500 to 2000 as 64, 67, 70, 75, 80 and see if that leans it out any.
EvilEvolution8 May 10, 2016 12:02 PM
Originally Posted by ridenrunwv (Post 11614577)
What cams and injectors?
All stock at the moment .
ridenrunwv May 10, 2016 12:03 PM
I was trying to edit posts because reading replies you made right as I posted so messed the order of posts up a bit.
EvilEvolution8 May 10, 2016 12:04 PM
Thanks a lot!! I will try! :)
EvilEvolution8 May 10, 2016 12:05 PM
In your opinion...the rest of RPM VE and the MAP VE is correct ?
ridenrunwv May 10, 2016 12:07 PM
Can't really tell just by looking at that. You could honestly have all different variations of data in tables and the car still run fine.
EvilEvolution8 May 10, 2016 12:10 PM
Ok perfect! :)
K1LLACAM172 Jun 22, 2017 04:26 AM
Bump
im having a similar issue with my load, it's 44% at idle and the car uses mid LTFT at idle and sometimes goes to low, any ideas? Did raising your RPM ve tables a bit help as suggested?
letsgetthisdone Jun 22, 2017 10:46 AM
Need to change the crossover points for your fuel trims. It shouldn't go to mid until like 55-60 load.
