-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   what are your EvoScan idle tps readings (https://www.evolutionm.net/forums/ecu-flash/211579-what-your-evoscan-idle-tps-readings.html)
Mad_SB Jul 14, 2006 08:39 AM
Hey folks,
what are your tps readings at idle, i normally show 13-15 at idle. Just woundering if my tps is off and should read 0 at idle???
MalibuJack Jul 14, 2006 08:41 AM
Mine definitely reads 0% at idle.. at least on the ECU+ have to look at the Evoscan logs to see there..
thatsMR2u Jul 14, 2006 08:43 AM
my evoscan is 12-13 at idle
laakness Jul 14, 2006 08:44 AM
Same here, 11-14...avg is 13ish
MalibuJack Jul 14, 2006 08:50 AM
I never noticed that it was over 0 at idle in Evoscan before.. That can't be right.. my regular logger shows 0%
laakness Jul 14, 2006 08:52 AM
I think some one mentioned this on the openecu boards and they were talking about how the pedal isn't being depressed at all but the engine is using some amount of throttle to keep it running...
I don't know if idle would be quite 13% but it was interesting.
Mad_SB Jul 14, 2006 08:54 AM
Still waiting on my ecu+ to show up....
But if you assume a linear scale from 0v to 5v with 0 being 0%tps and 5v being 100% a reading of 13 would correspong to .65 volts form the sensor which just about right isn't it?
MalibuJack Jul 14, 2006 08:55 AM
We don't have a throttle-stop though, our BISS and Idle stepper control Valve is a bypass system.. Doesn't touch the throttle blade at all..
If you check the voltage it should be about .6v closed.. It may be that numerically .6v calculates to 13% since EvoScan may be converting something that should be a voltage into a percentage..
AutoXer Jul 14, 2006 08:56 AM
Copy and pasted from this thread: https://www.evolutionm.net/forums/sh...d.php?t=210739
Originally Posted by AutoXer
I made the following observations via normal OBDII logging:
When the throttle is closed, the logger reads 0%
If you barely tap the throttle, the reading goes up... It seem to be well zeroed
Max throttle yields from 99.6 - 100%
The resolution seems to be 0.4%.... that equates to about 251 points from 0-100%
Cruizing on flat land(hard to find in WV) at 75MPH is about 20%
I pick up quite a bit of acceleration at 30%... well enough to pass on the interstate.
Open loop still seems to come in just under 30%
Mad_SB Jul 14, 2006 09:00 AM
I have a feeling that evoscan is doing a conversion on the voltage since at least several of us are getting 12-15 at idle and that is right around .6-.7volts.
MalibuJack Jul 14, 2006 09:02 AM
I have a good log I can look at later..
jcsbanks Jul 14, 2006 09:07 AM
mad VIII I previously posted in your other thread with details of the conversion, confirmation with voltmeter etc. Evoscan is simply reporting a % of 5V. Closed throttle is not zero volts and I wouldn't expect it to be. This is a good ECU stategy to determine faults I expect. On many cars 5V would also not be 100% throttle. Service manuals usually give a range such as 0.5+-0.2V to 4.5+-0.2V (this is a Subaru for example for closed and open). In fact the Evo does appear to swing to virtually 5V at open throttle.
modvp Jul 14, 2006 10:02 AM
I just checked mine and it's at 12.5...I guess that should equate to ~0.63 volts.
Edit: I forgot to add that my OBD2 scanner reads 0 volts when EvoScan registers the above value.
Mad_SB Jul 14, 2006 10:07 AM
JcsBanks & AutoXer,
I went back and read your previous posts again, I think i missed some of the info last time around.
So, in summary, regular odb-II logers may report 0% TP at idle while evoscan will report the voltage percentage on a 0-5v scale.
ez Jul 14, 2006 12:33 PM
Just to add...my EvoScan shows ~13%, but my Zeitronix logger, which is not OBDII, reads 0%
