Problem with fuel maps INF
I got a problem with my maps the high and low fuel maps say inf in them instead of numbers ever since i got tuned im wondering if there is a way to actually see the numbers if anyone knows what to do let me know asap
thank you |
anybody
What version of ECUflash are you using? It might a complication of 1.33 that no one has encountered yet. One other thing is if its asking you to use a certain definition that maybe doesnt actually work. Run through the procedure as you are doing it and what ECUflash is saying. It will help track it down possibly.
JB |
basically after pulling the map of the ecu the low and high octane fuel maps do not have numbers in them just inf i wish i could upload the file here for you guys to see but its too big even zipped
im using version 1.33 i used an older version and the same thing happened
Has the car been previously flashed? Do all the other tables work other than the ignition tables?
all tables work other than the fuel maps the car was flashed by a tuner a few weeks back
if you want i can email the map to you to check it out cuz i have no clue
Sure...let me PM you email.
anyone else can chime in on this
Your "tuner" changed the internal rom id and year to encrypt the tables. None of them worked for me at all. If you do in fact have an 05 (which i dont think you are mistaken on) the rom id shouldnt say 94170008 and 2004.
pm me your rom and the xml you're using .. I'll match it up if you like
Originally Posted by JohnBradley
(Post 4819205)
anyone else that could help me out
