Let's see your fully tuned timing maps
OK,
I'm re-tuning soon, and I want to see how far off I am from a "very good" tune. I'm particularly interested in tunes that have shown strong dyno powerbands and/or good quarter mile trap speeds. So please, post your timing map! I'll start with mine that I'm running as of today (this is straight 93, I run 25psi, with a taper to 20 at redline... still on stock turbo, stock WGA, stock mani/O2. The Green in my sig is "on order", and wga, ported mani/hotside/o2 are going in a the same time): http://images.puremhz.com/timing-020408.png |
I hope I'm not out of line when I say, damn thats a lot of peak timing, is that 14* peak? And at 25psi, must make for a fun drive...
100 oct. Mods in sig.
http://www.norcalmotorsports.org/use...ing_042107.gif Power chart: http://www.norcalmotorsports.org/use...owercurves.jpg |
Originally Posted by ShamelessCookie
(Post 4973094)
OK,
I'm re-tuning soon, and I want to see how far off I am from a "very good" tune. I'm particularly interested in tunes that have shown strong dyno powerbands and/or good quarter mile trap speeds. So please, post your timing map! I'll start with mine that I'm running as of today (this is straight 93, I run 25psi, with a taper to 20 at redline... still on stock turbo, stock WGA, stock mani/O2. The Green in my sig is "on order", and wga, ported mani/hotside/o2 are going in a the same time): http://images.puremhz.com/NLTS/HOTiming.gif |
Originally Posted by al\lupo
(Post 4973652)
How did you work on timing map #2 and #3?
Razorlab, have AFR for that hex or dyno?
This is for 93 oct and 25psi spike holding 20-21 to redline.
(note - I changed the scaling on both axis so be aware) http://www.skidmore.edu/~a_blaker/Misc/Timing%20Map.bmp |
100oct, just a 25psi spike but settles to 20. Dyno sheet in sig pic thread.
http://i182.photobucket.com/albums/x246/20psimr/ecu.jpg |
Here's mine. Tuned on E78 fuel at 28 psi with buschur intake, ams fmic, gsc s1 cams, 3" tbe, walbro 255, 1000cc injectors and gm bcs
http://ws.wamnet.com/~gryan/timing.JPG http://ws.wamnet.com/~gryan/380tq.JPG |
dudical, I assume that square of 4-5° is for the two step? What benefit does that give you ?
(Post 4974421)
Originally Posted by dudical26
(Post 4974193)
(note - I changed the scaling on both axis so be aware) http://www.skidmore.edu/~a_blaker/Misc/Timing%20Map.bmp So what kind of loads are you hitting @ peak and 7.5k ? Something like 280 falling to 220 ? |
Dont have any dyno charts yet, but last year when my 4K - 6K rpm (3rd) times were 0.3 seconds slower it was 305/304 on a MustangDyno and about 5 psi less with a wanker tune without WB. I won't guess my current #'s until I go again
http://i49.photobucket.com/albums/f264/C6C6CH3vo/h.jpg |
Originally Posted by matt55
(Post 4974745)
Originally Posted by C6C6CH3vo
(Post 4973770)
http://www.norcalmotorsports.org/use..._boost_afr.jpg |
