Official 2 byte thread!
Ok guys, since we are all sick and tired of going through a ton of threads to find the 2 byte HEX code and/or their appropriate MUT table locations for a particular 2-byte mod like 2-byte load, 2-byte RPM and 2-byte airflow (or you smart guys are sick of telling everyone over and over again,lol) I decided to make an official thread where i will just update this first post with any 2 byte locations you guys list for a particular ROM ID#.
I'm also adding the MUT 3D TABLE ADDRESS to the list. NOTE: If you currently don't have the 3D MUT TABLE installed in your ROM ID's XML file in ECUFLash (you may be using 1D tables for EACH 2byte mod location), download the attached file and save it onto your computer. Open it with NOTEPAD. Instructions on how to install it are inside the file. DOWNLOAD 3D MUT TABLE HERE! So if you've done some of these 2 byte mods already and don't mind looking in your tables to find the locations, it would help everyone out. I think this will save us ALL a great deal of time and be a viable resource. Thanks guys. ATTENTION EVOSCAN USERS! Be sure to edit the "RPM MUT 2 byte Mod" formula from 31.25*x to: 1000*x/256 OFFICIAL LIST: 88570008 2byte load MUT 00 = 6B12 MUT 01 = 6B13 2byte RPM MUT 02 = 6AFE MUT 03 = 6AFF 2byte AirFlow<-----------------------------------Need Confirmation MUT 04 = 6B6A MUT 05 = 6B6B MUT 3D TABLE ADDRESS = 35920 88580013 2byte load MUT 00 = 6B22 MUT 01 = 6B23 2byte RPM MUT 02 = 6AFE MUT 03 = 6AFF 2byte AirFlow MUT 04 = 6B7E MUT 05 = 6B7F MUT 3D TABLE ADDRESS = 373c4 88580014 2byte load MUT 00 = 6B22 MUT 01 = 6B23 2byte RPM MUT 02 = 6AFE MUT 03 = 6AFF 2byte AirFlow MUT 04 = 6B7E MUT 05 = 6B7F MUT 3D TABLE ADDRESS = 373c4 88590013 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = 6B1E MUT 03 = 6B1F 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 88590014 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = 6B1E MUT 03 = 6B1F 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 88590015 2byte load MUT 00 = 6B42 MUT 01 =6B43 2byte RPM MUT 02 = 6B1E MUT 03 = 6B1F 2byte AirFlow MUT 04 = 6B9E MUT 05 = 6B9F MUT 3D TABLE ADDRESS = 3EE84 88840013 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 88840016 2byte load MUT 00 = 6B22 MUT 01 = 6B23 2byte RPM MUT 02 = 6AFE MUT 03 = 6AFF 2byte AirFlow MUT 04 = 6B7E MUT 05 =6B7F MUT 3D TABLE ADDRESS = 377F8 88840017 2byte load MUT 00 = 6B22 MUT 01 = 6B23 2byte RPM MUT 02 = 6AFE MUT 03 = 6AFF 2byte AirFlow MUT 04 = 6B7E MUT 05 =6B7F MUT 3D TABLE ADDRESS = 37944 90550001 2byte load MUT 00 = 885C MUT 01 = 885D 2byte RPM MUT 02 = 883A MUT 03 = 883B 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 2e9e0 92460000 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 93660005 2byte load MUT 00 = 8960 MUT 01 = 8961 2byte RPM MUT 02 = 893E MUT 03 = 893F 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 33400 94170008 2byte load MUT 00 = 895C MUT 01 = 895D 2byte RPM MUT 02 = 893A MUT 03 = 893B 2byte AirFlow MUT 04 = 89BA MUT 05 = 89BB MUT 3D TABLE ADDRESS = 38060 94170014 2byte load MUT 00 = 895C MUT 01 = 895D 2byte RPM MUT 02 = 893A MUT 03 = 893B 2byte AirFlow MUT 04 = 89BA MUT 05 = 89BB MUT 3D TABLE ADDRESS = 38158 94170015 2byte load MUT 00 = 895C MUT 01 = 895D 2byte RPM MUT 02 = 893A MUT 03 = 893B 2byte AirFlow MUT 04 = 89BA MUT 05 = 89BB MUT 3D TABLE ADDRESS = 38158 96420007 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = 8962 MUT 03 = 8963 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 96420008 2byte load MUT 00 = 8984 MUT 01 = 8985 2byte RPM MUT 02 = 8962 MUT 03 = 8963 2byte AirFlow MUT 04 = 89E2 MUT 05 = 89E3 MUT 3D TABLE ADDRESS = 39FA0 96420011 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 96530006 2byte load MUT 00 = 898A MUT 01 = 898B 2byte RPM MUT 02 = 8962 MUT 03 = 8963 2byte AirFlow MUT 04 = 89E2 MUT 05 = 89E3 MUT 3D TABLE ADDRESS = 36200 96940011 2byte load MUT 00 = 899A MUT 01 = 899B 2byte RPM MUT 02 = 8976 MUT 03 = 8977 2byte AirFlow MUT 04 = 89F6 MUT 05 = 89F7 MUT 3D TABLE ADDRESS = 3F314 98640014 2byte load MUT 00 = 885C MUT 01 = 885D 2byte RPM <-----------------------------------Need Confirmation MUT 02 = 883A MUT 03 = 883B 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 2E9E0 98640016 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 2EA9C 98650014 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 99270000 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 99860002 2byte load MUT 00 = MUT 01 = 2byte RPM MUT 02 = MUT 03 = 2byte AirFlow MUT 04 = MUT 05 = MUT 3D TABLE ADDRESS = 302D8 |
These are RPM's:
88580013 = 6AFE/6AFF 88580014 = 6AFE/6AFF 94170008 = 893A/893B 94170014 = 893A/893B 96940011 = 8976/8977 88590013 = 6B1E/6B1F 88590015 = 6B1E/6B1F 96420007 = 8962/8963 |
Thank you sir! Updated.
96940011- 2Byte Airflow = MUT 04- 89F6
MUT 05- 89F7 |
Originally Posted by tseitz123
(Post 5316289)
MUT 05- 89F7 |
88580013 and 14 2byte load = 0xFFFF6b22
88590013, 14 and 15 2byte load = 0xFFFF6b42 of the top of my head, but im pretty sure thats right. you might want to include a section on howto configure up the MUT_TABLE :P |
these are 2byte load for:
94170008=same as 94170014 94170015=same as 94170014 88590015= 6b42/6b43 |
88840016 (and 99.9% 88840017):
2byte load MUT 00 = 6B28 MUT 01 = 6B29 2byte RPM MUT 02 = 6AFE MUT 03 = 6AFF 2byte AirFlow (did not tried yet) MUT 04 = 6074 MUT 05 = 6075 |
that looks like temp+baro corrected Al\lupo, maybe try 6b22/3 instead :)
Originally Posted by tephra
(Post 5316641)
2byte BASE load MUT 00 = 6B22 MUT 01 = 6B23 2byte CORRECTED (temp+baro) load MUT 00 = 6B28 MUT 01 = 6B29 BTW, could you please confirm 2 byte airflow addresses? |
(Post 5316558)
(Post 5316558)
Updated, hopefully i don't enter anything wrong ;) Thanks for the fast responses guys, we'll have this filled up in no time and you can all link the noob's here haha.
Originally Posted by bnice01
(Post 5316578)
ahh no, MUT_TABLES are in different locations on each different ROM, but the XML is the same for all ROM's just the address is different!
Yeah, thats what I said lol. like mine is address="38158" so I just need to have them understand that THIS is the # that needs editing before copying and pasting the code into their XML.
