How to disable immobilizer on EDM Evo9?
Hi m8s.
Does anubody know hot to disable the immo on a stock ecu EDM, Evo9? 88840013 for examble? Thanks in advance |
Why would you want to do this? You can't do it in the traditional sense. What you can do is use a transponder box that has the immo key inside. These boxes are normally made to allow for remote start on cars with these codes.
If you add the def for the Ecu periphery "faa"
Change the value from the stock value of 0x56Da to 0x56D2. If I was at home I could post the definition but I am sure its around here somewhere. If you have 0x56D8 in there as a value thats for turning off the rear O2 as well. You would want to change the value to 0x56D0. remember you have to add the 0x though it wont show up. |
Wow, I'd prefer to disable to immo as which means I won't have wire the transponder box to get remote start to work! The code is listed in the evo9base XML:
<table name="Immobilizer" category="Misc" address="3ffce" type="1D" level="3" scaling="Hex16"/> Not sure where to go from here though. |
<table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
Then change the value as I listed above. This works for any Evo that has the immobiliser enabled. |
thanks a lot m8s!!!
Today i'll test on one of our cars and i'll let you know the result. :) |
Did you lock yourself out of your ECU by flashing a ROM without the correct Immo code?
Will this work on USDM ROM's too? I am using 96940011
Originally Posted by JohnBradley
(Post 5421790)
Originally Posted by silex
(Post 5424597)
Originally Posted by hfalex
(Post 5423618)
thanks a lot m8s!!!
(Post 5420367)
Change the value from the stock value of 0x56D8 or 0x56Da to 0x5690. If I was at home I could post the definition but I am sure its around here somewhere. 5690 in bin is 101011010010000 56D2 in bin is 101011011010010 Stock should be 56DA 56DA in bin is 101011011011010 (notice that both bits are enabled) The second bit from the right is the rear O2 enable/disable. The fourth bit from the right is the immobilizer enable/disable. Eric |
Good call Eric..I was just going from memory on that one, I knew it was the immobiliser but I couldnt remember if it included an O2 or not.. Being EDM it probably doesnt have the second O2...again from memory.
56D0 -No rear O2 no Immobilizer
5650-no rear O2, No immobilizer, No knock 5658-no rear O2, No knock sensor 56D8-no rear O2 5698, no front or rear 02 5690, no front 02, rear 02, or immobilizer 56D2, No immobilizer went and looked at the list I worked up..here are the normal combos. |
(Post 5437456)
Eric |
