94170015 and 96530006 MAP to MAF Patch
hello all,
I have completed porting bez's map-to-maf patch to the 94170015 and 96530006(untested) roms. i am happy with the results. first try: http://img75.imageshack.us/img75/5980/mappatchpo2.png added idle resolution based on logs: http://img356.imageshack.us/img356/1997/try2mi5.png i have modded tephra's 94170015-5.10 and 96530006-5.10(untested) roms keeping all of his functionality as the MAP patch is pretty transparent. what this does: based on what i can tell, there is a map calibration table for your current sensor (mine is and 03 EVO 8 MDP so i have fudged some values that work great lol). it is used solely for this patch. there is a MAP temperature compensation table also solely for this patch which i have kept flat as per bez's original (probably will come in handy when going MAP only i dunno). finally there is a map to maf offset which i have set to 128 (int16/big endian/still need to figure out exactly wtf this does lol/i'll analyze the code when i get time) and a map to maf linear VE Table which i have set to use MAF during the latter ranges (noted value as '255'). basically, when MAP/MDP reading is vacume, the ECU will use MAP/MDP for fueling. you can prabably conclude this by my settings. this is great because I have different IC piping/Agency Power MAF pipe from hell/k&n cone/gt35r/272 cams/injectors/etc etc. i'm going to loosley conclude that these settings will work great on stock MDP'd evo 8's (94170015 variant) with any maf pipe/intake setup and not cause the dreaded idle stumble. remember, this is in the alpha stage of testing and may not produce my results on another evo. I have driven around a lot and tested this out. also, i have verified MAF is working during boost with my WB02. i have not disabled any maf error routines/so you cannot unplug it. SETTING THESE TABLES DIFFERENTLY WILL MAKE YOU RUN LINEAR MAP AND THUS LEAN UNDER HIGH BOOST SO DON'T TRY TUNING THIS WITHOUT A WB02/LIVE GAUGE :updown: here are the addresses for 94170015/2byte: FFFF898C is MAF value emulated by new MAP Routine FFFF8988 is RAW MAF VALUE FFFF8984 is RAW MAF value after filter here are the addresses for 96530006/2byte: FFFF89B4 is MAF value emulated by new MAP Routine FFFF89B0 is RAW MAF VALUE FFFF89AC is RAW MAF value after filter if the maf filtered value goes over the map emulated value, you will go lean as it will use the map emulated value. this can occur if you drastically change the settings. this can be observed in the logging. with my settings, the map emulated value is always higher above 1000 or so rpms/under throttle/boost/etc. at idle it fluctuates lightly. tephra: can i post this patch? here it is: EDIT: there seems to be a linked RPM value to the lean-spool trailing tables. no biggie, but i think this project is well underway with jcsbanks. thanks for all the input and feedback. i'll fix it, but it'll be useless as the other SD stuff is coming along nicely! |
sure thing... although using 5.10 would probably be better :)
you version looks a lot more simple that what I have seen b4... |
Originally Posted by tephra
(Post 6249999)
you version looks a lot more simple that what I have seen b4... i'll patch a 5.10 when all is good. its so damn simple anyways lol it just took me forever to get in tune with everyone else. i'm still not 100% there yet. :) |
Do you happen to have the settings that would be used for a JDM MAP?
Originally Posted by mfr122887
(Post 6250053)
EDIT: MAP/MDP ADC: 0xFFFF8416 if that helps any... (note this is only for 94170015 5.8+ versions of tephra's roms. if you log it on other roms, you will get a whole bunch of......nothing :)) |
This currently relies on the stock IAT sensor in the MAF for temperature compensation, correct?
Originally Posted by 03whitegsr
(Post 6254899)
my idle never stumbles lol though so i'm happy--i even have the OE idle settings too and now will go back to the stock 13 or so's in the low/idle load areas. i really need some more tuning and figuring out/logging what everything does. my car is down for clutch work as of today... |
This is a step in the right direction :thumbup:
Originally Posted by Jack_of_Trades
(Post 6254986)
thanks, i'll figure this out. in any event, the code can be manipulated to pull stuff from wherever. mixmastermatt i think might have some more useful input...the code is identical to the evo9 limiting/speed density patch. there is nothing but room for this in the 94170015 variant roms--tephra mods and all. i disassembled both (limiter and full) and cant find the difference between the map to maf routines. i'll keep digging though... |
As long as we can adjust for different MAPs being used, it'll be totally awesome.
good stuff bro
so have you tried running it with a IC piped disconnected? |
Originally Posted by bnice01
(Post 6255189)
good stuff bro
so have you tried running it with a IC piped disconnected? it should idle fine and rev to about 1200 or so fine with no ic piping as it sits, but i havent tested it. (EDIT: I should VTA my jdm diverter valve lol and youtube it--but no golfballs lol)
(Post 6255109)
--someone may already know the answer here, but i'm pretty new at the evo ecu stuff so it takes me a few [beers]. haha j/k |
Sweet patch,
Question as to what kinda of hardware you really need to get this going for MAP only? For example if i can use any MAP sensor i may pull out my 5 bar sensor for the ZT-2 unit and use it here or get another 3 bar sensor and put it where the mdp is. I can weld my own bung onto the UICP for air temps. |
Originally Posted by RoadSpike
(Post 6255294)
Sweet patch,
Question as to what kinda of hardware you really need to get this going for MAP only? For example if i can use any MAP sensor i may pull out my 5 bar sensor for the ZT-2 unit and use it here or get another 3 bar sensor and put it where the mdp is. I can weld my own bung onto the UICP for air temps. you will need a good/well placed iat sensor and wire it to the maf's baro/airtemp/whatever wiring making sure the ecu likes it. other than that, its tuning and fooling the ecu telling it the maf is there when its not hehe. EDIT: oh yeah, massive fuel tune reworking too. not hard though except for me. :crap: |
This is good movement on speed density for all. Just a suggestion do not know if it will work, but couldnt you use mrfred's IAT patch and then edit the code according to get the iat readings from the patched iat sensor?
