CEL P1400 after VSR intake install??
Im getting this code after the install of the AMS VSR intake... I still have the sensor plugged in as i was told to do and just sip tied up under the intake as theres of course nowhere to put it ont he VSR... but its pulling this code still. Do I even need this sensor or can i disable it? And if I can disable the CEL light for it how would I go about doing it? I have disabled my P0300 misfire code using the binary bit mod on my ECU. Can I do the same for this sensor and where would it be located?? Any help is greatly appreciated. The CEL in my face non stop is drving me nuts!!
you need a map sensor adaptor that ams sells (part number SKU1801) its a adaptor that your map sensor bolts to then you simply run a hose from the adaptor to a vac port on your monifold.
Other then the annoying CEL light is this going to hurt the car in anyway, performance or drivability wise?? I just drove it home from installing it.. so havent had mich time to see if its really affected anything.
I cant help you with this, but i can add a +1 to the problem. Ive also installed the AMS intake manifold and i now get Misfire errors as well. Ive also found it hard to get the idle running smooth after adding this intake.
I know its not the best section or thread, but have people found they don't really need to upgrade the intake manifold to make 600+whp? Sorry for the highjack |
Originally Posted by 300477
(Post 6532490)
Originally Posted by magyar86
(Post 6532162)
BumP! I'm also having the P1400 code.
If you do need a MAP adapter PM me... I have an extra left over from my 2g I'll sell for half price (barely used if ever).
As for the code, the OBDII database shows it as "P1400 Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)". I don't know if that is the correct code or what sensor you are talking about as (very unfortunately :D) I don't have any experience with the VSR aside from oogling. |
Periphery2 (FCA) bit10 will disable the P1400 test, but the car still may not run well depending on what model year car.
Originally Posted by mrfred
(Post 6678186)
Would it affect the 94170015? |
Originally Posted by steadly2004
(Post 6679136)
What exactly is the manifold pressure sensor used for? Does the ECU take it into consideration when calculating load?
