"ABS" goes nut w/ EvoScan cable?
I've finally got my cable to work with both EvoScan and EcuFlash!! But one little thing that bothers me is that my "ABS" goes nuts, even I did have the pin1 pulled out in my cable - so the "ABS" should not flash when my cable is connected, but it does still flash from times to times though, meaning sometimes it flashes, and sometimes it doesn't after I either re-start the car or the laptop or un/re-plug the cable.
Anyone has the same experience?? Knowing why/what is causing it?? Is this something we should get worried for?? :confused: |
Never heard of the ABS light flashing but the ACD lights yes...
It may flash while you are trying to log the AYC/ABS ecus. Are you sure you pulled the correct pin?
Originally Posted by fostytou
(Post 6671223)
I believe the pin is starting from right to left as following: 8 7 6 5 4 3 2 1 15 14 13 12 11 10 9 And "Pin 9" is the one, right?????????????????????????? :confused: Anyone knows what the Pin 9 is supposed to log then?? So that i can double check if that logging function still working. Or, is the Pin 9 being used by the EcuFlash at all...Look what i've done!! |
Mine does the same thing, I haven't noticed any issues w/ logging though.
If you were trying to pull pin 9 and pulled the one on the opposite side of the plug i believe it is accesory power for the flash cable. It is something important, but I believe you wouldnt be able to flash properly if you pulled it. Can you still flash OK?
http://www.auterraweb.com/obdiipinout.html Note the image at the top there. You are looking at the OBDII plug itself with pin 9 on the lower left. If you were looking at the pins on your cable it would be the lower right. |
(Post 6671828)
http://www.auterraweb.com/obdiipinout.html Note the image at the top there. You are looking at the OBDII plug itself with pin 9 on the lower left. If you were looking at the pins on your cable it would be the lower right. Anyone has their pin 9 pulled out as well?? Now that I recall, they do have an option for one with Pin 9 or without Pin 9 when you place an order, and I apparently missed that part so they shipped me the one w/ Pin 9. But then, following their instruction, all you need to do is to twist it off for it to work w/ Mitsu!! Well, then maybe the EcuFlash is not using the Pin 9 at all - {thumbup} |
you have to remove pin 9
