ALT field fault.
i have fitted an e8 ecu into my e2.one fault that appears is for the alt field.does anyone know how to disable it?
P# code??
think its po622 ill double check in the morning.basically pin 33 and 41 in the evo 8(260EDM) are for the alt g and fr terminals which the early evo does not have on the ecu.i also have a fault for the evap emission circuit(purge valve).again the early evo does not use this.
