The DTC Disable thread (P1235, P1241, P1238, etc)
So after a brainwave I looked and found the counters pertaining to DTC discovery.
You know - how long does the ECU have to detect the condition for before pooping out a DTC? Anyways here is my list so far: 53040010: Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631ea" type="1D" scaling="Hex16"/> Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631ae" type="1D" scaling="Hex16"/> 52360016: Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="62b9a" type="1D" scaling="Hex16"/> Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631b2" type="1D" scaling="Hex16"/> Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631ae" type="1D" scaling="Hex16"/> 53040007: Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="633e8" type="1D" scaling="Hex16"/> Code:
<table name="Enable catalytic monitoring (P0420)" category="Misc" address="503BC" type="1D" scaling="Hex8"/> Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631ea" type="1D" scaling="Hex16"/> OK - you need todo 1235/1233/1234 all together, otherwise you will still get codes if you JUST disable 1235 :) |
38 ms before the 1235 would set no wonder you had to have that just right. Thanks. Will let you know tommorow if this all works.
Cheers C |
yeah I dont think P1235 is in milliseconds, manual states 0.36 second...
So is the previous airflow disable code no longer needed?
yeah... but this is less intrusive, hopefully it works :)
Originally Posted by tephra
(Post 7420992)
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631ae" type="1D" scaling="Hex16"/> Now these havn't really been tested, so it would be good to get some people to test before newbies (sorry but some are!) try this stuff :) If I was misleading the thread to any point please forgive my newbieness:( Think you can share the addresses for 53040007? I'll triple check before posting:) |
Originally Posted by e_leo
(Post 7421194)
The disable in the other thread worked for me only for the situation I described.
If I was misleading the thread to any point please forgive my newbieness:( Think you can share the addresses for 53040007? I'll triple check before posting:) Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631b2" type="1D" scaling="Hex16"/> |
nice find, my local guy is waiting on parts and then coming back, he finally started getting one of the CEL from time to time.
cool - well im going to be ramping up the boost on my beast soon so i will test it too once I get a reliable CEL :) hehe
I'll test this today after work. Thanks for all your work.
Cool :)
I'd test, but no problems with DTCs thus far
Awesomeness...
so how do i disable my cel caused by HFC and rear 02 sensor
The way I understood things was that P1235 indicates a boost spike, right? It detects more air coming in at a certain RPM and TPS than expected, and initiates limp mode to prevent that from causing damage. I've been having issues with this for a while now where I was hitting over 25.5psi at 3.5k rpm, so a fix seems like a blessing... but...
Isn't it still a good safety net? And can't the conditions under which P1235 is issued be tuned for higher boost/bigger turbos by tuning the Airflow Check tables? Am I understanding P1235 correctly? Under what circumstances would you NOT want to disable this code? Sorry for being the noob :) |
