Important ECU Thread Links
I closed the other thread and started this as the OP was no longer active on EvoM. Please PM me with any thread link addition ideas. I want this to be as complete and useful as possible for all of us.
**********ECU WIKI PAGE********** ROM Patches: Latest Tephra Patch: https://www.evolutionm.net/forums/ec...hramod-v7.html tephra mod v7 - tephra https://www.evolutionm.net/forums/ec...ur-answer.html v7 questions & answers Legacy (EOL) Tephra Patches: https://www.evolutionm.net/forums/ec...d-v5-10-a.html tephra mod v5.10 - tephra https://www.evolutionm.net/forums/sh...d.php?t=297825 PATCH: NLTS + Valet + KnockCEL by Tephra https://www.evolutionm.net/forums/sh...ight=byte+load 96940011 05 EVOVIII ROM: Known Patches Additional ECU Features: Speed Density https://www.evolutionm.net/forums/ec...ched-roms.html How To: Speed Density - Scheides https://www.evolutionm.net/forums/ec...y-patches.html Speed Density patches - jcsbanks Boost Control: https://www.evolutionm.net/forums/sh...d.php?t=293981 Direct ECU boost control by mrfred https://www.evolutionm.net/forums/sh...d.php?t=288408 Fine tuning Load based boost control to prevent weather based boost variation by mrfred https://www.evolutionm.net/forums/sh...d.php?t=276674 HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid - Evo_Kid https://www.evolutionm.net/forums/sh...d.php?t=227006 HOW TO - Control boost using ECUFLash and the stock boost solenoid - Evo_Kid OBD/Emissions https://www.evolutionm.net/forums/ec...us-mrfred.html forced obd inspection pass - acamus & mrfred https://www.evolutionm.net/forums/ev...-canister.html how to: egr/emissions system removal - fostytou https://www.evolutionm.net/forums/ec...solenoids.html disabling egr/fuel pressure solenoids - fostytou (Page 9/10 preliminary how to with pictures) https://www.evolutionm.net/forums/ec...ml#post6613499 Forced O2 heater pass Raising Load Limits: https://www.evolutionm.net/forums/ec...nge-638-a.html doubles fuel cut load limit - mrfred Advanced Logging: https://www.evolutionm.net/forums/la...o-evoscan.html Logging an AEM UEGO w/o a serial cable - darkmitsu https://www.evolutionm.net/forums/sh...d.php?t=259595 JDMMAP sensor set-up - mrfred https://www.evolutionm.net/forums/ec...ial-cable.html log afr from lc-1 w/o a serial cable - mrfred https://www.evolutionm.net/forums/ec...e-logging.html Manifold Air Temp Logging - mrfred https://www.evolutionm.net/forums/sh...ight=byte+load 94170008 ROM 2 byte load mod for dummies (like me :) by A418t81 https://www.evolutionm.net/forums/sh...hlight=dummies Evo IX 2-byte Load & Lean Spool for Dummies by Pd1 https://www.evolutionm.net/forums/sh...d.php?t=259494 log WGDC in EvoScan - mrfred (good info on solenoid TBEC) https://www.evolutionm.net/forums/ec...ging-help.html Troubleshooting AEM UEGO wideband logging issues - tips and tech info Tuning Tips and Tricks: How To's https://www.evolutionm.net/forums/sh...d.php?t=302895 How to Tune an Evo by nj1266 https://www.evolutionm.net/forums/ec...-ecuflash.html Visual Training - How To: Tune an evo with Ecuflash - recompile https://www.evolutionm.net/forums/ec...s-how-tos.html ecu pin removal/installation/map switching harness how to - mrfred Virtual Dyno Simulator https://www.evolutionm.net/forums/ec...simulator.html Virtual Dyno Room Simulator - jack of trades Map Smoothing Tool https://www.evolutionm.net/forums/sh....php?p=6053943 Autosmoothing tool by Jumperalex Injector Tuning https://www.evolutionm.net/forums/ec...upermerge.html Consolidated info from Fast Freddie Start-up Fuel and ISCV Tables https://www.evolutionm.net/forums/ec...cv-tables.html Thread from Jamie at Dynotech Tuning Lean Spool Tuning https://www.evolutionm.net/forums/ec...s-enabled.html lean spool tuning - appauldd Advanced Tuning https://www.evolutionm.net/forums/sh...d.php?t=327185 official 2 byte load w/ mut address - jack of trades https://www.evolutionm.net/forums/sh...d.php?t=201146 ECUflash tutorial for beginners - EFIxMR https://www.evolutionm.net/forums/ec...ble-found.html Knock control - load vs RPM table found - jcsbanks https://www.evolutionm.net/forums/sh...jector+scaling Injector Scaling by various members https://www.evolutionm.net/forums/sh...d.php?t=249388 MAF Scaling by SophieSleeps https://www.evolutionm.net/forums/sh...t=mivec+tuning Mivec Tuning by John Bradley the mivec guru (Page 10 and on are more useful information) https://www.evolutionm.net/forums/ec...cy-tables.html Turbo Efficiency Tables https://www.evolutionm.net/forums/ec...ter-spool.html Tuning for Faster Spool https://www.evolutionm.net/forums/ec...-searched.html Tuning for POOR Cold Idle Advanced ECU Development https://www.evolutionm.net/forums/ec...e-lookups.html beginners guide to ecu table lookups - advanced material - logic & many more Again, any additional links that you think should be here PM me or post in this thread. |
reserved for text
reserved for text 1
Great idea
I know this is missing some important threads so please post. I did a little organization to break ti up a little bit but feel free to make any suggestions. This thread is to help you guys so i can change whatever to fit what you guys want.
How about my cold start/idle thread? It has a lot of coverage.
Nice update.
if I think of any threads that should be added, ill be sure to let you know. edit- shouldn't you just condense the two 'advanced logging' sections? just a thought And injecor scaling and maf scaling should be under a "fuel" category, IMO. |
Originally Posted by Appauldd
(Post 7685190)
The tutorial on how to scale your Maf isnt working!
Originally Posted by CMB
(Post 7732944)
I vote for jumperalex's autosmoothing excel sheet to be added :)
Good idea,thanks :)
opps double post, please delete
Please add....
Turbo Efficiency Tables https://www.evolutionm.net/forums/ec...cy-tables.html Tuning for Faster Spool https://www.evolutionm.net/forums/ec...ter-spool.html Tuning for POOR Cold Idle https://www.evolutionm.net/forums/ec...-searched.html |
