94170715 V7 Issues
I am pleased that this rom is available so no bad kharma.
But...Ha The MUT requests that were in the 9653 rom are not working. In particular I am interested in the following. MUT40 = 1byte gear MUT42+MUT43 = 2byte SPEED/RPM ratio (to get your gear ratios correct - if you need to) I also think that the following are not correctly configured in the MUT table MUT00+MUT01 = 2byte airflow (ie MrFreds mod in g/s or lb/min) MUT02+MUT03 = 2byte airflow (ie MAFHz) I put the following addresses to get the 2byte arflow MAFHz to work correctly MUT02=89BA and MUT03=89BB I also noticed that the Max WGDC vs coolant temp address is off in appauldd's xml. Anyone know the correct address? It is currently 56D2. |
For those who want to log 2 byte loads
2byte load raw = 895C and 895D 2byte load + baro compensated = 8960 and 8961 2byte load + baro and IAT compensated = 8962 and 8963 The load for afr is raw and timing is baro-iat compensated |
Sorry.....I forgot to change those in the MUT table.
Good call ! ! |
I will update my posting in the wiki with the accurate findings.
Thanks. |
Please post any other 9417 v7 issues here so that we can help solve them.
Frankly, I need a good 9417 base file (that is 94170015 and evo_7_base). From what I can tell from tuning the first 03 I've been in this weekend the evo_7 base and evo_7_base_new are both junk in v1.42.
Does anyone have a well compiled and clean set of those two XMLs? |
Originally Posted by fostytou
(Post 7971282)
Originally Posted by Appauldd
(Post 7971297)
Catch me on AIM or google chat....same SN as here. I can hook you up.{thumbup}
Has anyone gotten this rom to work with the map tracer? I get an "object reference not set to an instance of object" every time I try to do anything with the 94170715 V7 rom, but thats the only one. My 88590715 rom and the 94170008 rom work great, as well as the 94170015 v5.10 rom. For some reason I can't even get evoscan to try to open it. I've tried the usual -cutting it down to the scalings and the maps -setting to unix file type -copying my working 88590715 xml that is cut down and changing the map addresses. The error seems to happen even when there is no xml for that romID in the directory (when it would normally allow you to select where the xml is) so I think it may be some incompatibility with the ROM. I even went as far as to verify the romID in a hex editor at 0x0f52 ! Working in evoscan v2.6. Any help would be appreciated.... |
(Post 7972129)
Replied back with a little note :)
After fighting with evoscan maptracer--using the above tricks--one of which I helped identify, I have given up on the POS. I do not give up easily either. I also use the excel maptracer...
I never really used map tracker to view my logs. I guess it would be a good feature though.
Since all you gents are using the excel maptracer, has anyone got the bigmap maptracer to work with office 2003?
I'll check to see which version of Excel I have when I get home, but I'm using the bigmap version with no issue....love that program ALOT more than the evoscan maptracer.
(Post 7972129)
Has anyone gotten this rom to work with the map tracer? I get an "object reference not set to an instance of object" every time I try to do anything with the 94170715 V7 rom, but thats the only one. My 88590715 rom and the 94170008 rom work great, as well as the 94170015 v5.10 rom. For some reason I can't even get evoscan to try to open it. I've tried the usual -cutting it down to the scalings and the maps -setting to unix file type -copying my working 88590715 xml that is cut down and changing the map addresses. The error seems to happen even when there is no xml for that romID in the directory (when it would normally allow you to select where the xml is) so I think it may be some incompatibility with the ROM. I even went as far as to verify the romID in a hex editor at 0x0f52 ! Working in evoscan v2.6. Any help would be appreciated.... I ported the evo7base xml into the 94170015 xml (taskes some time) and just linked the tephra rom with 94170015 and eliminated the link to the evo7base. Perhaps the 3 links were throwing it off in evoscan? |
The Max WGDC vs Coolant temp table does look a little odd.
